[PATCH] MAXPATHLEN bug on GNU
[PATCH] MAXPATHLEN bug on GNU Robert Millan 03 Apr 13:48
  [PATCH] MAXPATHLEN bug on GNU Sven Neumann 03 Apr 14:09
   [PATCH] MAXPATHLEN bug on GNU Robert Millan 03 Apr 20:25
    [PATCH] MAXPATHLEN bug on GNU Raphaël Quinet 04 Apr 13:52
   [PATCH] MAXPATHLEN bug on GNU Patrick McFarland 04 Apr 04:14
    [PATCH] MAXPATHLEN bug on GNU Sven Neumann 04 Apr 08:41
Robert Millan
2003-04-03 13:48:08 UTC (about 22 years ago)
hello!
MAXPATHLEN is used unconditionaly in gimp's sources. POSIX allows not to define it, so systems that don't have a path length limit, like GNU, break on building the gimp.
please apply this little patch to fix it:
--- gimp1.2-1.2.3/app/app_procs.c.old 2003-03-29 19:39:54.000000000 +0100 +++ gimp1.2-1.2.3/app/app_procs.c 2003-03-29 19:40:26.000000000 +0100 @@ -132,7 +132,11 @@
static gint logo_area_width = 0;
static gint logo_area_height = 0;
static gint show_logo = SHOW_NEVER; +#ifdef MAXPATHLEN
static gint max_label_length = MAXPATHLEN; +#else
+static gint max_label_length = 0;
+#endif
void
2003-04-03 14:09:34 UTC (about 22 years ago)
Robert Millan writes:
generally, you should use Bugzilla (http://bugzilla.gnome.org/) to report such problems. In this particular case, I'll take care of fixing it right now, so there's no need to open a bug report for it.
+#endif
well, actually this is just an initialization and MAXPATHLEN is a rather bad choice anyway. I'll just change it to some sane fixed value instead.
Salut, Sven
Robert Millan
2003-04-03 20:25:37 UTC (about 22 years ago)
Sorry. I looked for a bug tracking system in the gimp site but couldn't find any sign of it. will note for next time.
ok, thanks!
Patrick McFarland
2003-04-04 04:14:37 UTC (about 22 years ago)
So _what is_ a good sane fixed value?
2003-04-04 08:41:33 UTC (about 22 years ago)
Patrick McFarland writes:
any value is as good as any other since if the code works correctly the inital value is never used. I've choosen 64 which should be a reasonable choice if for some reason the initialization would not be performed (which would be a bug).
Salut, Sven
Raphaël Quinet
2003-04-04 13:52:58 UTC (about 22 years ago)
http://www.gimp.org/
On the homepage, you find this nice paragraph:
Bugs, bugs, bugs! The current development version of Gimp is loaded with tons of bugs, as Bugzilla will show you in the _list_of_open_bugs_ (including the _list_of_enhancement_proposals_). If you think you've found a new one, you can _submit_a_bug_report_.
If the links on the home page (present since March 2000) are not sufficient, you can also go to http://www.gimp.org/devel_ver.html (the page about the development version of the GIMP) and you will see a nice table of links that can be used to query the bug database in various ways.
So it shouldn't have been that hard to find a sign of a bug database... ;-)
-Raphaël
