Keybindings
8 of 8 messages available
Keybindings Owen 02 Apr 00:47
  Keybindings Sven Neumann 02 Apr 12:33
  Keybindings Sven Neumann 02 Apr 12:40
   Keybindings Raphaël Quinet 02 Apr 14:16
  Keybindings Owen 03 Apr 11:26
   Keybindings Raphaël Quinet 03 Apr 13:00
   Keybindings Sven Neumann 03 Apr 13:26
    Keybindings Owen 03 Apr 21:22
Owen
2003-04-02 00:47:27 UTC (about 22 years ago)
2003-04-02 12:33:39 UTC (about 22 years ago)
Keybindings
Owen writes:
I've updated keybindings.txt,tex and pdf to match the cvs as at 31 Mar
http://www.webone.com.au/~oc/gimp/keybindings.pdf http://www.webone.com.au/~oc/gimp/keybindings.tex http://www.webone.com.au/~oc/gimp/keybindings.txt
The PDF looks rather nice and I think we should include it with the tarball. Is there a reason the .txt version is so horribly aligned if viewed with a fixed-width font? Would you mind if I fix it before I commit to CVS?
Salut, Sven
2003-04-02 12:40:37 UTC (about 22 years ago)
Keybindings
Owen writes:
there's one more thing you might want to change. Your version states that keybindings can be dynamically reassigned. This is not any longer possible by default. You need to explicitely turn this feature on in the preferences dialog (labelled as "Dynamic Keyboard Shortcuts").
The idea behind this change is that this prevents users from accidentally reassigning shortcuts. The user should be advised that in order to change the keybindings, she should enable Dynamic Keyboard Shortcuts in the prefs, do the changes and redisable the feature afterwards.
Salut, Sven
Raphaël Quinet
2003-04-02 14:16:27 UTC (about 22 years ago)
Keybindings
On 02 Apr 2003 12:40:37 +0200, Sven Neumann wrote:
Owen writes:
ObBugzilla: http://bugzilla.gnome.org/show_bug.cgi?id=106991
While you are updating the text, please fix the spelling mistake at the end of the second paragraph: "it's binding" should be "its binding".
Suggestion for re-writing that paragraph:
The GIMP allows menu keybindings to be dynamically re-assigned. So if you don't like these, they are easy enough to change. To do this, you should first activate the "Dynamic Keyboard Shortcuts" in the preferences dialog. Then you can just highlight the menu item of your choice, and press the desired new key combination. If that combination is already assigned, the old command will lose its binding.
And please use a fixed-width font while editing the text file. This will ensure that all shortcuts are correctly aligned. You can check this by viewing the text file in a web browser, for example. It looks like the paragraphs in the text file were wrapped at line 65 (instead of the default 70 or 72). If you are using Emacs for editing the text file, you can use M-: followed by (setq fill-column 65) to wrap the text to the same column as in the original file.
-Raphaël
Owen
2003-04-03 11:26:34 UTC (about 22 years ago)
Keybindings
On Wed, 2 Apr 2003 08:47:27 +1000 Owen wrote:
I've re-updated keybindings.txt,tex and pdf to match the cvs as at 31 Mar.
The text file now lines up is ok in Mozilla and with less and it's is its
The keybinding reassignment paragraph rewritten, thanks Raphaël
Owen
Raphaël Quinet
2003-04-03 13:00:56 UTC (about 22 years ago)
Keybindings
Thanks! The text file looks much nicer now and both versions have a better introduction text. I would still like to add one more thing, maybe as a separate paragraph after the second one:
The Alt key is generally reserved for keyboard access to the menus. You can for example use Alt+F to access the File menu, etc. As in other GTK+ applications, you can then use the arrow keys or any of the underlined keys to navigate in sub-menus, select specific options or cycle through several options using the same shortcut key.
Feel free to re-write that paragraph if you find a nicer way to explain this. Also, the part with the underlined keys is not really true yet (especially for the filters) but hopefully it will work soon.
I also spotted one error in the file:
Filters Repeat "GFig".......................Alt+F Re-Show "GFig"......................Shift+Alt+F
This should be replaced by:
Filters Repeat "(Last Filter)"..............Ctrl+F Re-Show "(Last Filter)".............Shift+Ctrl+F
-Raphaël
2003-04-03 13:26:08 UTC (about 22 years ago)
Keybindings
Owen writes:
I've committed the updated keybindings.txt to CVS. I'm not sure what to do about the PDF version. We already have quick_reference.ps which serves a similar purpose but is outdated. Do you intend to extend the PDF to include the information that is in quick_reference.ps now? Should it perhaps be named gimp-quick-reference.pdf (or similar) then?
Salut, Sven
Owen
2003-04-03 21:22:14 UTC (about 22 years ago)
Keybindings
On 03 Apr 2003 13:26:08 +0200
Sven Neumann wrote:
Owen writes:
I have now uploaded the post script file from which the pdf file was made,
http://www.webone.com.au/~oc/gimp/keybindings.ps
quick_reference.ps (and tex) is a different document all together. It shows mouse combinations and actions etc. I have yet to start on that one.
keybindings.pdf was produced as an alternative to the text file, looks better.
Anyway, leave it to you.
Owen
