building 1.3 - libart .pc not found - minor update
building 1.3 - libart .pc not found - minor update Michael J. Hammel 21 Feb 02:37
  building 1.3 - libart .pc not found - minor update Sven Neumann 21 Feb 12:39
Michael J. Hammel
2003-02-21 02:37:05 UTC (about 22 years ago)
On Thu, 2003-02-20 at 10:17, Sven Neumann wrote:
and I remember to have sent you a reply to that list already. You are using the wrong version of libart. You should use libart_lgpl as noted in the file INSTALL.
I just noticed the path provided in the INSTALL file is no longer correct. Currently it says:
ftp://ftp.gnome.org/pub/gnome/pre-gnome2/sources/libart_lgpl/
But the real path is
ftp://ftp.gnome.org/pub/gnome/sources/libart_lgpl/
And yes, this version (2.3.11) works. Thanks.
2003-02-21 12:39:53 UTC (about 22 years ago)
"Michael J. Hammel" writes:
OK, fixed in CVS. Thanks for the report.
Salut, Sven
