Script-Fu "Erase every other row" not erasing every each other row
Script-Fu "Erase every other row" not erasing every each other row | Piotr Legiecki | 17 Feb 08:10 |
3E4CC99A.7080600@club-inter... | 07 Oct 20:21 | |
Script-Fu "Erase every other row" not erasing every each other row | Tor Lillqvist | 15 Feb 03:02 |
Script-Fu "Erase every other row" not erasing every each other row | Tor Lillqvist | 15 Feb 22:02 |
Script-Fu "Erase every other row" not erasing every each other row | Manish Singh | 15 Feb 22:19 |
Script-Fu "Erase every other row" not erasing every each other row | Tor Lillqvist | 16 Feb 02:43 |
3E4C250A.15633.F1E1CE@local... | 07 Oct 20:21 |
Michael Schumacher writes:
> the "erase every other row" script-fu seems to be
> broken. Sometimes, the wrong row is deleted. A sample image showing
> this effect is available here:
> http://www.gimp.de/1044969327/1045147200/1045173183/streifen.png
Jean-Louis Hamel writes: > Conclusion: there is a bug in the last version of GTK+, probably a > rounding error when computing the dimensions of a selection rectangle > (or perhaps the feather option always applied...).
I can confirm this bug, but I find it very hard to believe that it would be caused by some bug in GTK+. GIMP's selections (especially when created programmatically, from script-fu, and not via user input) have nothing to do with GTK+.
It's easy to demonstrate the essence of this bug by creating a small image, say 10x20 pixels, zoom it up so you can see the pixels, fill it with black, and enter in the Script-Fu console:
; (this is a comment) Show the image's ID, assuming you have only one ; image open. If this is a fresh GIMP, it's typically 0 (aref (cadr (gimp-image-list)) 0)
; Show its single layer's drawable ID. Typically 2.
(gimp-image-active-drawable )
; where is the number printed above
(gimp-rect-select 0 12 10 1 REPLACE FALSE 0) (gimp-edit-clear )
This should clear pixel row 12 to white, and does so.
(gimp-rect-select 0 14 10 1 REPLACE FALSE 0) (gimp-edit-clear )
This should clear pixel row 14, but in fact clears row 13!
Has anybody noticed this with a recent CVS GIMP 1.2 on Unix?
--tml
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Get 128 Bit SSL Encryption!
http://us.click.yahoo.com/FpY02D/vN2EAA/xGHJAA/e4wwlB/TM
List archives: To unsubscribe send a blank message from the address you're subscribed to
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
It turns out the bug is caused by Trio, the printf/scanf implementation included in GLib 2.2, and used on for instance Win32. (The main cause to use Trio instead of the C library's printf/scanf on some platform is that the C library doesn't have a C99-compatible snprintf() or positional printf parameters.)
When script-fu passes for instance the number 14 as a double to gimp,
wire_write_double() uses g_snprintf("%0.50e") to write it out to the
pipe as a string. g_snprintf() uses trio, which for some reason
produces the string
"1.39999999999999991118215802998747676610946655273438e+01" (and not
"1.40000000000000000000000000000000000000000000000000e+01", as I
perhaps naively would have expected).
In GIMP, in wire_read_double(), this string is then converted back into a double in with the C library sscanf("%le"), producing 13.999999999999998. When this is converted to an integer in rect_select_invoker() when calling rect_select(), you get 13.
Sigh. I'll do some more testing and file a detailled bug report on GLib/trio. Or is this a bug in GIMP, should it do some tiny amount of rounding of the last significant digits in wire_read_double? I am no floating point expert, does that make any sense?
Or is the bug in Microsoft's C library? Should scanf()ing the above string produce the double 14, and not something a tiny bit less.?
--tml
When script-fu passes for instance the number 14 as a double to gimp, wire_write_double() uses g_snprintf("%0.50e") to write it out to the pipe as a string. g_snprintf() uses trio, which for some reason produces the string
"1.39999999999999991118215802998747676610946655273438e+01" (and not "1.40000000000000000000000000000000000000000000000000e+01", as I perhaps naively would have expected).In GIMP, in wire_read_double(), this string is then converted back into a double in with the C library sscanf("%le"), producing 13.999999999999998. When this is converted to an integer in rect_select_invoker() when calling rect_select(), you get 13.
It looks to be trio's fault, there is a bug similar to this opened already:
http://bugzilla.gnome.org/show_bug.cgi?id=101874
Perhaps special case this on windows to use the native snprintf (I assume it exists there). This isn't an issue in GIMP 1.3, since we don't transmit doubles as text over the wire anymore.
Probably we should do byte order negotation in the wire protocol at some point.
-Yosh
(gimpwin-users readers can largely ignore this message... just keeping this thread there, too, as it started there)
Manish Singh writes:
Perhaps the simplest solution for GIMP 1.2 would be to change wire_write_double():
diff -u -2 -r1.14 gimpwire.c
--- gimpwire.c 30 May 2000 23:38:46 -0000 1.14
+++ gimpwire.c 16 Feb 2003 01:20:28 -0000
@@ -437,5 +437,5 @@
for (i = 0; i < count; i++)
- g_snprintf (buf, sizeof (buf), "%0.50e", data[i]);
+ g_snprintf (buf, sizeof (buf), "%0.*e", DBL_DIG, data[i]);
if (!wire_write_string (channel, &t, 1))
return FALSE;
I.e. don't use more digits than necessary, especially as some printf implementations (like Trio) might misbehave. (When asked for precision DBL_DIG, Trio does print 14 as "1.400000000000000e+01".) This might also improve speed a bit on all platforms, no need for the printf implementation to generate 50 digits...
BTW, what has been the rationale behind using floating-point for pixel coordinates in the PDB in the first place, for instance for gimp_rect_select?
--tml
Well, I'm not sure if it is the same bug but scaling under linux sometimes (and the images are quite big, about 1000x700) causes verital blank line across the image. When I change the target image to something slightly smaller/larger this line disappears.
This looks like rounding error not OS dependant.
Piotr L.
