startup tips need review
startup tips need review Sven Neumann 09 Feb 11:54
  startup tips need review Carol Spears 10 Feb 07:22
2003-02-09 11:54:57 UTC (about 22 years ago)
I think it is about time to think about updating the Tip of the Day messages for GIMP 1.3. A few of them are incorrect and probably the new user interface makes some new hints necessary. The tips are organized in an XML file which is found in the tips directory. If you start editing it, make sure you edit the file gimp-tips.xml.in. The file gimp-tips.xml also contains translations and is created from that source.
So if someone wants to take the job of reviewing the tips, please speak up here.
Salut, Sven
Carol Spears
2003-02-10 07:22:05 UTC (about 22 years ago)
On 2003-02-09 at 1154.57 +0100, Sven Neumann typed this:
i will be happy to collect the suggestions and submit them after it quiets down.
