GIMP from CVS and gtk-doc
GIMP from CVS and gtk-doc Sven Neumann 07 Feb 15:04
2003-02-07 15:04:07 UTC (about 22 years ago)
I just want to inform you that in order to build the HEAD branch of The GIMP with API documentation you will need a recent version of gtk-doc (>= 1.0) as well as a reasonable setup to handle DocBook XML (basically libxslt with xsltproc) If you run into problems, you can disable the build of the API reference by passing --disable-gtk-doc to autogen.sh.
As usual, release tarballs will contain the documentation in HTML so users of the tarball don't need to worry about all this.
Salut, Sven
