Script to get a list of GIMP contributors automatically
Script to get a list of GIMP contributors automatically Raphaël Quinet 20 Dec 00:22
Raphaël Quinet
2002-12-20 00:22:20 UTC (over 22 years ago)
A few days ago, there was a discussion about how to get a "fair" list of GIMP contributors. I thought that it would be extremely difficult to generate such a list automatically from the various ChangeLog files in the source tree, from Bugzilla, from the web site updates, etc.
To prove myself wrong, I started writing a script that can parse a ChangeLog file and extract the dates, names and e-mail addresses from all entries, check for the names of contributors mentioned in the text, check for the names of patch files, etc. The script is far from finished, but it already works better than I expected. If you are curious and you want to see a quick hack turned into a Perl monstrosity, you can take a look at this: http://www.gimp.org/~raphael/parse_gimp_changelogs.pl Currently, the script takes only one optional parameter: the name of the ChangeLog file to read (so you can parse "ChangeLog.pre-1-2" or "po/ChangeLog"), the default is "ChangeLog" in the current directory.
The output is not very pretty, but gives an idea of what the script could output when it is finished: it displays a list of GIMP contributors, sorted by the number of times they are mentioned in the ChangeLog. The current output is biased towards those who have CVS commit access, because they are credited even when they apply a patch supplied by someone else. Also, the way the script detects the names is not perfect and requires lots of special cases in the code. But I am trying to improve that. I know how to solve these problems (I designed the parser in such a way that I can correctly credit the patch authors) but I do not have the time to write the missing code today. There is a short TODO list near the top of the file. If you want to see what kind of information is collected by the script while it runs, you can uncomment the various "print" statements in the code. I recommend that you uncomment the line: # print Dumper (@contributors);
located near the end of the file if you want to see how the list looks like internally (this is a list of hashes of lists).
I repeat: the script is not finished yet and I am still working on it. I am making it available now because I will be away from the 'net for ten days (no e-mail) and maybe some of you may want to play with it before I am back.
In the meantime, have a merry Christmas and a very GIMPy new year!
-Raphaël
