ANNOUNCE: Gimp-Print 4.2.5-pre1
ANNOUNCE: Gimp-Print 4.2.5-pre1 Robert L Krawitz 08 Dec 22:39
Robert L Krawitz
2002-12-08 22:39:57 UTC (over 22 years ago)
Gimp-Print 4.2.5-pre1 contains the following major changes over Gimp-Print 4.2.4:
1) The Epson Stylus Photo 950/960/PM-950C and 2100/2200 are now tuned. The 950 and 960 are fully tuned, while the 2100 and 2200 are fully tuned with Photographic Black ink. Matte Black ink on the 2100/2200, and dark yellow ink on the PM-950C, are not tuned at this point.
As a special note, all of these printers print especially fast at 360 DPI in Four Color Standard mode (in color, grayscale, and monochrome). For this reason, we recommend use of Four Color Standard for printing text and low-resolution graphics on plain paper with these printers.
2) Epson Stylus Photo printers with an automatic paper cutter option (the Stylus Photo 925, 950/960/PM-950C, and 2100/2200) now enable the cutter. This has received some testing, but has not been tested comprehensively.
3) The Epson Stylus Pro 5000 should now print correctly, although this is not yet tested.
4) The Epson Stylus Color 640 now prints properly in grayscale and monochrome at 720 DPI and above.
5) DESTDIR now works with 'make install' in the Gimp plugin directory (this is generally of interest only to packagers).
6) The user manual should now install correctly on all platforms.
7) The version of libtool used to build this release has been changed to 1.4.3. This enables the packaged source to compile correctly on a few architectures (this is generally of interest only to packagers).
8) Updates to the Debian packaging (this is of interest only to Debian packagers).
The following bugs have been fixed in Gimp-Print 4.2.5-pre1:
596538 Epson Stylus Photo 925 etc. paper cutter is not functional 599029 Epson: Maximum speed printing not supported on 950, 960 625780 Epson Stylus Pro 5000 does not print 639356 Build system: libtool 1.4.2 does not work on all platforms 641628 QUALITY: Epson Stylus 2200 print quality is low in 7-color 645895 Epson stc640 does not print at 720dpi and above 646158 Build:DESTDIR broken in make install in print plugin 649253 QUALITY - Epson 950/960 problems in all resolutions
The following bugs are currently open:
409612 Epson: Minor positioning problem on 4x6 glossy 538097 QUALITY-Canon S400 dark and yellow cast 549677 Canon BJC-1000 functions incorrectly at 720x360 DPI 557868 QUALITY-HP DeskJet 560 is washed out 581168 Canon BJC 250 just spits out pages 601767 Mac OS X: Canon BJC 2100 does not print multiple pages 602933 QUALITY-Canon S800 dark and grainy 613054 Mac OS X: Printing from InDesign 2.0 on OS 10.2.1 614882 QUALITY - Canon BJC-55 is too pale and desaturated 621668 Epson Stylus full bleed prints have slight margin 627266 Mac OS X: Autoselect option incorrectly offered 627978 QUALITY: Canon BJC-6500 has magenta cast. 631937 HP DesignJet Sheet Cutter Problem 641981 QUALITY: HP DesignJet 455 too light
