regex+
28 of 28 messages available
regex Robin Rowe 25 Nov 04:10
regex Sven Neumann 25 Nov 12:08
regex Robin Rowe 26 Nov 19:36
  regex+ Simon Budig 26 Nov 20:08
  regex Guillermo S. Romero / Familia Romero 26 Nov 20:13
regex+ Robin Rowe 26 Nov 21:06
  regex+ Guillermo S. Romero / Familia Romero 26 Nov 21:16
  regex+ Simon Budig 26 Nov 21:19
  regex+ Sven Neumann 27 Nov 13:08
   regex+ David Neary 27 Nov 16:01
regex+ Robin Rowe 26 Nov 23:36
  regex+ Carol Spears 27 Nov 02:06
regex+ Robin Rowe 27 Nov 08:28
  regex+ Simon Budig 27 Nov 10:18
  regex+ Carol Spears 27 Nov 11:08
   regex+ Sven Neumann 27 Nov 13:19
    regex+ Carol Spears 27 Nov 16:26
     regex+ Guillermo S. Romero / Familia Romero 27 Nov 19:48
regex+ Robin Rowe 27 Nov 21:12
regex+ Robin Rowe 27 Nov 21:19
  regex+ Dov Grobgeld 28 Nov 14:12
   regex+ Sven Neumann 28 Nov 16:50
   regex+ Shlomi Fish 28 Nov 17:31
regex David Weeks 28 Nov 00:32
  regex Christian Rose 28 Nov 01:59
  regex Simon Budig 28 Nov 11:52
regex Adam D. Moss 28 Nov 00:46
  regex David Weeks 28 Nov 06:46
Robin Rowe
2002-11-25 04:10:12 UTC (over 22 years ago)
regex
Hi. GIMP has its own regex.c that the procedural database uses. That seems to look up plug-ins using regexec. I'm having a little difficulty understanding the logic of the code. Can anybody explain how regex is used by GIMP? Why is it necessary?
Thanks!
Robin --------------------------------------------------------------------------- www.FilmGimp.org
www.LinuxMovies.org
www.OpenSourceProgrammers.org
2002-11-25 12:08:53 UTC (over 22 years ago)
regex
"Robin Rowe" writes:
GIMP doesn't use it's own regex implementation any longer. We only provide one as a fallback for the case that libc doesn't have the regex functionality we need. This is the code in the regexrepl directory that you'll find in the toplevel source directory.
The regex code is used by gimp-plug-ins-query (and a similar function in script-fu). I don't understand how you can not understand this code since it seems pretty straight-forward. Could you elaborate on your problems?
Salut, Sven
Robin Rowe
2002-11-26 19:36:29 UTC (over 22 years ago)
regex
Sven,
Yes, I can follow that from the code. I understand what regex does generally, just not why gimp-plug-ins-query needs it.
My confusion relates to script-fu and gimp plug-ins with respect to regex. Why query a plug-in as a regular expression? What's the point?
Thanks!
www.LinuxMovies.org
Simon Budig
2002-11-26 20:08:41 UTC (over 22 years ago)
regex+
To have a nice way to specify a search pattern. For thinks like a PDB-Browser for example.
Bye,
Simon
2002-11-26 20:13:23 UTC (over 22 years ago)
regex
rower@MovieEditor.com (2002-11-26 at 1036.29 -0800):
Gimp keeps a DB of info about all plugins. In startup all are checked, if they changed since last time, they are queried, asking them what they do, and the replies are stored. The regex is used to search in the DB that stores all the info. Read gimp-procedural-db-query and gimp-plugins-query in / Xtns / DB Browser, and guess how the browser works. :]
GSR
Robin Rowe
2002-11-26 21:06:59 UTC (over 22 years ago)
regex+
Simon,
regex.
Ok, I guess I'm just not making my question clear. I understand that regex enables doing a wildcard search in the plug-ins database.
What I have trouble imagining is the scenario where regex search in Gimp is necessary or useful. Few users even know how to phrase a regex search. Is this just feature-itis? Do I correctly surmise that regex could be removed without being missed?
Thanks,
www.LinuxMovies.org
2002-11-26 21:16:44 UTC (over 22 years ago)
regex+
rower@MovieEditor.com (2002-11-26 at 1206.59 -0800):
It will be missed by persons that use the DB as a tool, like script or filter writers, not users. If you want to call that featuritis or not useful...
GSR
Simon Budig
2002-11-26 21:19:15 UTC (over 22 years ago)
regex+
Well, maybe it is a little used feature, but I do not understand why we should remove it?
It enables powerful searches over the various help texts plugins provide via their Registration. I surely do not understand why having this feature might be considered a bad thing.
Bye, Simon
Robin Rowe
2002-11-26 23:36:28 UTC (over 22 years ago)
regex+
Simon,
Thanks for the insights from you and Guillermo. I think I understand now.
There's no reason you should remove it from Gimp. The motive behind my question is I am considering whether to remove regex from Film Gimp. Never having used that feature, I was just trying to figure out what it really does.
Cheers,
Robin
www.LinuxMovies.org
Carol Spears
2002-11-27 02:06:08 UTC (over 22 years ago)
regex+
well, i use it. honest. Robin, ever try to write a gimp plug-in?
On 2002-11-26 at 1436.28 -0800, Robin Rowe typed this:
Simon,
Cheers,
Robin
www.LinuxMovies.org
Robin Rowe
2002-11-27 08:28:53 UTC (over 22 years ago)
regex+
Carol,
How would regex help me write a gimp plug-in?
Cheers,
www.LinuxMovies.org
Simon Budig
2002-11-27 10:18:22 UTC (over 22 years ago)
regex+
Search for functions that you could use in the plug-in...
Bye, Simon
Carol Spears
2002-11-27 11:08:44 UTC (over 22 years ago)
regex+
this is such a good topic for a tutorial! i needed help to see this stuff at first as well. i don't have time to write the tutorial, but i got some screenshots for it when i have the time.
i have been working with gimp-python lately, so i chose that console for my tutorial. the script fu console works the same way, so if you haven't installed the python module in your gimp, you can use that one that comes with gimp.
Xtns -->Python Fu -->Console will bring up this dialog: http://carol.gimp.org/mygimp/tutorials/dbbrowser/gimp_pdb-browser.png i needed the gradient list for my last plug-in.
after you find the call you need and hit the okay button, it is back to that original dialog:
http://carol.gimp.org/mygimp/tutorials/dbbrowser/gimp_python-console2.png
see, it gets cooler now. it is the same dialog, yet in the little text box at the bottom is the call you queried about only in the way that python understands it. also, it shows what the return is. this thing does most of the work for you ...
so, for the best part, you need to remove the equal sign and everything to the left of it (this will leave pdb.gimp_gradients_get_list() in the text box. hit enter and see this(!!): http://carol.gimp.org/mygimp/tutorials/dbbrowser/gimp_python-console3.png
whee!
carol O
n 2002-11-26 at 2328.53 -0800, Robin Rowe typed this:
Carol,
Cheers,
www.LinuxMovies.org
2002-11-27 13:08:51 UTC (over 22 years ago)
regex+
why would you want to remove a feature that is implemented in libc anyway? All you'd gain is one nice feature less.
Actually I don't understand at all why you are dealing with this code. It seems unrelated to 16-bit or floating point support. If you ask me, stop fiddling with this stone-old code base and try to help building a gimp core that fits the needs of film-editing.
Salut, Sven
2002-11-27 13:19:11 UTC (over 22 years ago)
regex+
Carol Spears writes:
nice stuff, but, sorry, you are not using any regex features here...
Salut, Sven
David Neary
2002-11-27 16:01:43 UTC (over 22 years ago)
regex+
Ever the diplomat, Sven. I think the point is probably to do a trawl through legacy code and see how much of it can be flushed, if any. At least that's how I took it. Now that Robin knows that the regex code is useful, at least to some people, he's not planning on touching it.
Cheers, Dave.
Carol Spears
2002-11-27 16:26:55 UTC (over 22 years ago)
regex+
hmm ...
On 2002-11-27 at 1319.11 +0100, Sven Neumann typed this:
even the part where the "search by name" button gets pushed?
2002-11-27 19:48:16 UTC (over 22 years ago)
regex+
cspears@cablespeed.com (2002-11-27 at 1026.55 -0500):
In the plain DB browser you can write "^plug.*blur" and hit that button. Last time I checked, "^plug.*blur" was a regex, that meant "has plug first (nothing before it), then something, then blur".
GSR
Robin Rowe
2002-11-27 21:12:04 UTC (over 22 years ago)
regex+
Carol,
Hi. Thank you for the detailed response. I found that enlightening.
Cheers,
www.LinuxMovies.org
Robin Rowe
2002-11-27 21:19:28 UTC (over 22 years ago)
regex+
David,
I wish! Sometime later.
Although regex is available with *nix, it isn't part of Windows. My choice is to remove it or fix the broken regex implemenation included in Film Gimp. That regex code is full of difficult to debug macros.
I'm not?
Cheers,
www.LinuxMovies.org
David Weeks
2002-11-28 00:32:36 UTC (over 22 years ago)
regex
Robin,
I called you right the first time. You don't know jack about much, and nothing about the rest of it. You're to green to phathom, let alone be embarassed, by your suggestion to remove regular expressions. This is *nix, and that's how *nix works. That's why *nix works. And GIMP is an *nix thing. Don't like it? Quit working with computers and go back to the garbage you came from -- AKA Microsoft.
See, it's like this: Unix is American, Microsoft is French. That Microsoft does NOT have it is an endorsement to have it. That Microsoft would have it is a caution if you do.
All this time you thought you worked with computers. NOT! Microsoft products are necesarrily products that let people like you think you're developing. They let people who don't know anything about computers work with computers. They make it "easy". Only it isn't easy, their stuff never works, their customers never learn, and that leaves it to the *nix folks to build stuff that really works.
I bet you don't even know what globbing characters are you're that ignoRANT. And RANT you've done.
You should drop this project. I've no confidence in the work of someone so clearly clueless.
I'm surprised your mail isn't in html!
David Weeks
Adam D. Moss
2002-11-28 00:46:11 UTC (over 22 years ago)
regex
[blah blah blah]
[blah blah blah]
Wow. At least when /I'm/ drunk I take my mindless babbling to IRC where it fits in just fine.
Christian Rose
2002-11-28 01:59:26 UTC (over 22 years ago)
regex
tor 2002-11-28 klockan 00.32 skrev David Weeks:
Robin,
David,
please keep childish name-calling rants like this for yourself. Thanks.
Kind regards, Christian
David Weeks
2002-11-28 06:46:43 UTC (over 22 years ago)
regex
So Adam, what kept from doing so this time?
Anyone who a) doesn't know what regular expressions are, and b) thinks a project is better without them is c) not fit for work in *nix. gimp or otherwise.
Call it a basic competence. A basic competence.
Soberly yours,
David Weeks
On Wednesday 27 November 2002 06:46 pm, Adam D. Moss wrote:
David Weeks wrote:
I called you right the first time. You don't know jack about much, and nothing about the rest of it. You're to green to fathom
[blah blah blah]
[blah blah blah]
Simon Budig
2002-11-28 11:52:34 UTC (over 22 years ago)
regex
Huh?
The Gimp-Developer Mailing list is *not* about personal insulting people you apparently don't like.
While the approach taken by Robin - brushing up an ancient codebase - might be questionable, I highly appreciate that he is contributing to the Gimp project. This apparently can not be said about you - at least I am unable to find any reference to you in the Changelogs or in the AUTHORS file.
Please stop flaming around with people that try to help.
Thanks, Simon
Dov Grobgeld
2002-11-28 14:12:47 UTC (over 22 years ago)
regex+
Perhaps replace it by pcre (www.pcre.org). It is pretty widely used these days.
Perhaps an advanced settings button that would toggle search by regular expression or literal string button would be the best. I think taking away a power option for the sake of simplicity is the wrong approach. Make simple things simple. Make complex things possible.
Dov
On Wed, Nov 27, 2002 at 12:19:28PM -0800, Robin Rowe wrote:
David,
I'm not?
Cheers,
www.LinuxMovies.org
Gimp-developer@lists.xcf.berkeley.edu http://lists.xcf.berkeley.edu/mailman/listinfo/gimp-developer
2002-11-28 16:50:23 UTC (over 22 years ago)
regex+
Dov Grobgeld writes:
before you (or Robin) start to look for yet another regex replacement, you should probably have a look into the current GIMP development tree which has the problem solved already.
Salut, Sven
Shlomi Fish
2002-11-28 17:31:17 UTC (over 22 years ago)
regex+
The problem with Perl-compatible regular expression is that they are NP-complete:
http://perl.plover.com/NPC/
"Normal" regular expressions are polynomial time. Throughout the entire years I used Perl, I think I avoided most of the features that make it NP-Complete and stuck to the regular expressions feature set, even if it made my code more complicated. Perl programmers who use the entire Perl feature set can easily cause their program to run very slowly.
If you have Perl-compatibility in mind, you can use PCRE. But sometimes supplying only traditional regexps is not a bug but a feature as it ensures fast processing.
Shlomi Fish
That may be nice. For instance the Microsoft Word or DevStudio Find feature has an option to toggle regexps on and off. So does Konqueror. Regexps are very nice but they may confuse simpletons. ("When I search for '?' it stops at every character")
Shlomi Fish
Dov
David,
I'm not?
Cheers,
www.LinuxMovies.org
