+ restoring mouse position after use corner navigation tool
9 of 9 messages available
+ restoring mouse position after use corner navigation tool Marco Munari 25 Nov 02:59
  + restoring mouse position after use corner navigation tool Guillermo S. Romero / Familia Romero 25 Nov 16:32
   + restoring mouse position after use corner navigation tool Sven Neumann 25 Nov 20:42
    + restoring mouse position after use corner navigation tool Guillermo S. Romero / Familia Romero 25 Nov 20:59
+ restoring mouse position after use corner navigation tool Sven Neumann 25 Nov 12:23
  + restoring mouse position after use corner navigation tool Roger Leigh 26 Nov 00:30
  + restoring mouse position after use corner navigation tool Christopher W. Curtis 26 Nov 05:56
   + restoring mouse position after use corner navigation tool Sven Neumann 26 Nov 14:56
    + restoring mouse position after use corner navigation tool Christopher W. Curtis 28 Nov 03:27
Marco Munari
2002-11-25 02:59:10 UTC (over 22 years ago)
just an idea:
I notice that mouse navigation tool, in the lower right corner of drawing window, could be improved in usability: before drag the viewing area is better to save the mouse position, restoring it after viewable area is moved and mouse released.
i mean the mouse pointer in navigation preview shortcut is absolutely not moved to change the mouse pointer context.
v
I think it's better that after the use of ccorner view drag tool, the mouse stay in the used tool, don't you think so?
gdk: gdk_fb_mouse_get_info (&winx, &winy, mask);
xlib: XQueryPointer( dpy, w, &root_win, &win, &x, &y, &win_x, &win_y, &state_mask )
All the best, MARco
2002-11-25 12:23:28 UTC (over 22 years ago)
Marco Munari writes:
I'm not sure if warping the mouse cursor would be an improvement in useability. Usually doing so is considered a bad thing by user interface guidelines.
what do you mean when you say 'mouse stay in the used tool' ??
gdk:
these are function to retrieve the pointer position, but they don't allow to set it. There's no way we will introduce calls to the GdkFB layer or let alone Xlib. Of course there's a way to get the pointer position using plain GDK, but I think there's still no way to warp the pointer to a different screen location.
Salut, Sven
2002-11-25 16:32:05 UTC (over 22 years ago)
mar@cf.nettuno.it (2002-11-25 at 0259.10 +0100):
Let me try to understand it:
+-------------------------+ it is, but not exactly there.
If there is a thing to change, it is to let the cursor go out of the preview if the user keeps dragging, thus make screen / mouse relation more tied, not less.
GSR
2002-11-25 20:42:06 UTC (over 22 years ago)
"Guillermo S. Romero / Familia Romero" writes:
might make sense. Another thing to change is that we currently try to open the preview window in such a position that the pointer is in the correct spot within the navigation preview. This approach is doomed to fail if the image window is close to the lower or right edge of the screen. We should probably warp the pointer if this happens.
Salut, Sven
2002-11-25 20:59:05 UTC (over 22 years ago)
sven@gimp.org (2002-11-25 at 2042.06 +0100):
Would not make more sense something like in drop menu (the one used for layer modes, if out of screen, it scrolls in as you keep / push the pointer in the border)? Maybe too complex.
But at least "happy warping" should be avoided if possible, that is sure.
GSR
Roger Leigh
2002-11-26 00:30:27 UTC (over 22 years ago)
Sven Neumann writes:
OpenLook on SunOS used to do this by default. It was fast, but took a lot of getting used to. You have to find the cursor after every move, which is annoying. Dropping the mouse cursor where you consider it needed next is doubly annoying if the user wants to do something else (perhaps unrelated to your program).
2002-11-26 05:56:09 UTC (over 22 years ago)
It's been quite some time since I've done any X programming, but I recall having a function that would bound the pointer within a box. Should this exist, you could bound the cursor and then release it, perhaps after a motion event (I'm not sure how immediately the bounding event happened). :-\
Chris
2002-11-26 14:56:19 UTC (over 22 years ago)
"Christopher W. Curtis" writes:
please keep in mind that we don't do any X programming here; we need a GDK equivalent. IIRC, you can confine the pointer into a GdkWindow when calling gdk_pointer_grab(). However I did not understand your argumentation above. Are you saying that we should try to warp the pointer by using this functionality?
Salut, Sven
2002-11-28 03:27:41 UTC (over 22 years ago)
I think "should" is too strong a word. You said that there was no way to do it. Well, this might be a way. An ugly hack, perhaps, but a way. If you really wanted to do it and had no other means to ...
Whether or not this *should* be done I'll leave up to you.
Chris
