CALL FOR VOLUNTEERS: GTK experts out there for Gimp-Print?
CALL FOR VOLUNTEERS: GTK experts out there for Gimp-Print? Robert L Krawitz 10 Nov 22:04
Robert L Krawitz
2002-11-10 22:04:49 UTC (over 22 years ago)
Are there any GTK/Gimp toolkit experts out there who'd like to help out with the Print plugin? I'm in the process of making some fairly significant architectural changes to the libgimpprint library; basically everything's a lot more dynamic than has been the case up until now. The current print plugin creates all of the widgets up front, so there's a static set of parameters. The new library allows (at least in principle; the implementation hasn't caught up yet) much more dynamic specification of options; different printers can support different options, and even the set of options currently selected can influence the options and choices available.
The API (which currently isn't even on the development mainline; it's on a branch of its own) is still in some flux; experiences with the Print plugin are needed to help shape it.
This is likely to be a fairly significant rewrite. However, this kind of change is going to be needed to support more flexible options in the 4.3/(4.4|5.0) Gimp-print.
