ANNOUNCE: Gimp-Print 4.2.3
ANNOUNCE: Gimp-Print 4.2.3 Robert L Krawitz 19 Oct 16:09
Robert L Krawitz
2002-10-19 16:09:11 UTC (over 22 years ago)
Gimp-Print 4.2.3, released October 19, 2002, is a stable release in the Gimp-Print 4.2 series.
Gimp-Print is a suite of printer drivers that may be used with most common UNIX print spooling systems, including CUPS, lpr, LPRng, or others. These drivers provide high quality printing for UNIX (including Macintosh OS X 10.2 and newer) and Linux systems in many cases equal to or better than proprietary vendor-supplied drivers, and can be used for many of the most demanding printing tasks.
This software includes the Print plug-in for the Gimp, and GhostScript and CUPS drivers, including Foomatic data.
The Gimp Print plugin requires the Gimp 1.2.
The CUPS driver requires CUPS 1.1.9 or higher. 1.1.14 or above is highly recommended, as certain translation-related bugs are fixed and it is possible to print true CMYK.
The Ghostscript driver requires GNU Ghostscript 5.10, 5.50, 6.51, or any later GNU Ghostscript release based on 6.51 (e. g. 6.52). It may also be used with GNU Ghostscript 7.05, or with ESP Ghostscript 7.05.
The IJS GhostScript plugin driver requires GNU Ghostscript 6.53 or later, ESP Ghostscript 7.05 or later, or APFL GhostScript 7.04 or later.
Users of Macintosh OS X 10.2 and above can use this package, as the printing system is based on CUPS, which is supported by Gimp-print. Note that Macintosh OS X 10.0 and 10.1 (including 10.1.5) cannot use this package. We recommend that Macintosh OS X users download the precompiled installer package from http://gimp-print.sourceforge.net rather than attempt to build this package from source, as using the installer is much simpler. We further recommend that Macintosh OS X users install ESP GhostScript, to permit printing from Carbon applications (such as most Adobe applications) that generate PostScript rather than PDF output. Directions for that are also available at http://gimp-print.sourceforge.net.
Please read the README file for full instructions on installing this package.
Gimp-Print 4.2.3 contains the following major changes over Gimp-Print 4.2.2:
* Major Bugs Fixed:
1) (bug 604854) The Epson Stylus Color 600, 800, 850, 1520, and 3000 did not print correctly at 1440x720 DPI (much too dark). These printers now print correctly.
2) (bugs 620016 and 619992) Two problems with the IJS driver have been fixed. The first problem is that the IJS driver did not print correctly in grayscale or monochrome; the second is that a spurious fine line was printed at the very top of each page.
3) (bug 613384) The Epson Stylus Pro 7600 and 9600 did not print at all. While this printer is not fully tuned, it now prints correctly.
4) (bug 621667) Very large prints (longer than about 40" long) on Epson Stylus Pro printers were not printed correctly; the print is typically chopped into many small pieces.
5) (bug 615561) The Epson Stylus Color 480 and 580, and C20, C40, C41, and C42 (all variants) did not print in black and white or grayscale. This was a regression in 4.2.2.
6) (bug 611804) The CUPS driver did not compile correctly on many platforms other than Linux (this was known to be an issue on Solaris and BSD). This was a regression in 4.2.2.
* New Functionality:
1) The native CUPS driver now accepts custom paper sizes with printers that permit this (all Epson printers, and most others). To use this on the lp or lpr command line, use
-o PageSize=Custom.300x400
where 300 and 400 should be replaced by the width and height of the page in 1/72" units.
The width and height can also be specified in inches ("in"), cm, or mm. For example, for 4.5x7.5-inch paper you can specify:
-o PageSize=Custom.4.5x7.5in
On Macintosh OS X, custom page sizes may be defined and selected through the Print Manager.
2) The Foomatic interface now accepts custom paper sizes with Foomatic 2.0.1.
This works with all spoolers. Here are sample command lines for all spoolers, for CUPS the syntax is the same as with the native CUPS drivers of GIMP-Print and units are again points ("pt" or nothing), inches ("in"), cm, and mm:
CUPS: lpr -o PageSize=Custom.500x750mm bigposter.ps LPRng: lpr -Z PageSize=Custom.500x750mm bigposter.ps GNUlpr: lpr -o PageSize=Custom.500x750mm bigposter.ps LPD: lpr -JPageSize=Custom.500x750mm bigposter.ps PPR: ppr -F "*PageSize Custom" -i 500x750mm bigposter.ps PDQ: pdq -oPageSize_Custom -aPageWidth=500 -aPageHeight=750 -oPageSizeUnit_mm bigposter.ps No spooler: directomatic -o PageSize=Custom.500x750mm bigposter.ps
This works with both the GhostScript "stp" and the IJS interface of GIMP-Print.
3) A Japanese translation has been added.
4) This release contains an ijsgimpprint package for Debian.
The following bugs have been fixed in Gimp-Print 4.2.3:
604854 QUALITY-Epson 1520 and 3000 print too dark at 1440x720 DPI 611804 rastertoprinter.c fails to compile on Solaris 613384 Epson 7600 no printing
615561 Epson C40UX cannot print in B&W and Gray 615759 360x240 bad horizontal position 619992 IJS driver prints spurious first line 620016 IJS driver does not print properly in monochrome 621667 Very large prints on Epson 9500 fail 622612 CUPS driver forbids custom page sizes
The following bugs are open against Gimp-Print 4.2.3:
409612 Minor positioning prob on 4x6 glossy 538097 QUALITY-Poor quality printing on Canon s400 549677 Incorrect scaling on Canon BJC-1000 557868 QUALITY-Washed out color under Gimp on HP560c 581168 BJC 250 just spits out pages
601767 Mac OS X: Canon BJC 2100 does not print multiple pages 602933 QUALITY-Poor quality on Canon S800 603702 QUALITY-HP LaserJet 5L print is too light 613054 Printing from InDesign 2.0 on OS 10.2.1 614882 QUALITY - Problems with CANON BJC-55 - Gimp-Print 619299 QUALITY - brightness adjustment problem 619537 QUALITY - Poor quality w/ Lexmark OprtaE+ & pcl-4 621668 Full bleed prints have slight margin 625602 QUALITY Pale output on Stylus Pro 7500
