Need Help...
Need Help... Kirk Patton 18 Oct 02:46
Kirk Patton
2002-10-18 02:46:17 UTC (about 23 years ago)
Need Help...
I am trying my hand at producing my first perl plugin.
I want to be able to quickly generate a printable sheet of pictures from a single source. Ex. wallets, 5x7's or an 8x10.
My program is working, kind of...
I am coding the portion that is designed to produce a matrix of 9, 2.5"x3" wallets.
My problem is that the columns and rows of pictures are not ligning up properly. :-(
I checked my code by printing out the coordinates that are generated and they check out o.k.
I am stuck for ideas as to what may be the problem.
I was wondering if anyone on the list could take a peak at the code to see if I was doing something silly.
The program is attached.
Thanks, Kirk
___
