how to make Gimp::Perl script work remotely?
how to make Gimp::Perl script work remotely? | forest monk | 26 Sep 16:56 |
how to make Gimp::Perl script work remotely? | Marc) (A.) (Lehmann | 27 Sep 00:47 |
how to make Gimp::Perl script work remotely? | forest monk | 27 Sep 04:01 |
how to make Gimp::Perl script work remotely? | Marc) (A.) (Lehmann | 27 Sep 23:56 |
how to make Gimp::Perl script work remotely? | forest monk | 28 Sep 03:20 |
how to make Gimp::Perl script work remotely? | Marc) (A.) (Lehmann | 29 Sep 01:41 |
how to make Gimp::Perl script work remotely? | forest monk | 01 Oct 17:28 |
Hi All,
I have a Gimp::Perl script that works fine locally and i wanna make it work
through networking. Say, If i start a gimp perl server on a server machine,
what should i do to be able to execute the script on a remote machine?I
searched online resources and found that on server side, i need to setenv
GIMP_HOST to [auth@][tcp/]hostname[:port] for tcp support, but what should i
do on client side? do i need to install some client tools on the box or
should i modify my script to include gimp::net module?
TIA
__________________
On Thu, Sep 26, 2002 at 02:56:06PM +0000, forest monk wrote:
through networking. Say, If i start a gimp perl server on a server machine, what should i do to be able to execute the script on a remote machine?I searched online resources and found that on server side, i need to setenv GIMP_HOST to [auth@][tcp/]hostname[:port] for tcp support, but what should i do on client side? do i need to install some client tools on the box or should i modify my script to include gimp::net module?
Just the same, i.e. use sth. like this:
GIMP_HOST=password@10.0.0.1
and start the server, and then do the same on the client and start the perl script. You shouldn't need to modify your script, although modifying it can make some things easier (program structure can be much freeer, as you can decide when to conenct and disconnect).
Hi pcg Marc,
Thanks a lot for your reply. Tried what you suggested but still could not
get it to work. Got some error message like "Cannot locate Gimp.pm at @INC
The following are the exact steps i did:
1.setenv GIMP_HOST password@1.2.3.4 on server box A(where the gimp, perl,gtk
etc are installed);
2.start gimp perl server on server box A;
3.setenv GIMP_HOST password@1.2.3.4 on client box B;
4.start the script on client box B;
I am sure that the script works fine locally on server box A and there is no firewall issue between box A and B. Any insights will be very appreicated.
TIA
To: forest monk
CC: gimp-developer@lists.xcf.berkeley.edu Subject: Re: [Gimp-developer] how to make Gimp::Perl script work remotely? Date: Fri, 27 Sep 2002 00:47:05 +0200On Thu, Sep 26, 2002 at 02:56:06PM +0000, forest monk wrote:
machine,
setenv
should
or
-- -----==- | ----==-- _ | ---==---(_)__ __ ____ __ Marc Lehmann +-- --==---/ / _ \/ // /\ \/ / pcg@goof.com |e| -=====/_/_//_/\_,_/ /_/\_\ XX11-RIPE --+ The choice of a GNU generation | |
__________________
On Fri, Sep 27, 2002 at 02:01:57AM +0000, forest monk wrote:
Thanks a lot for your reply. Tried what you suggested but still could not get it to work. Got some error message like "Cannot locate Gimp.pm at @INC .....".
this actually looks as if gimp-perl wasn't installed at all. You have to have gimp-perl on both machines, of course.
Hi Mac,
Thanks again for your reply. I do appreciate it. Not sure about one thing
though: Do I only need the perl and gimp-perl module installed on my client
box and no more software (Gtk+, GIMP) required?
Regards
To: forest monk
CC: gimp-developer@lists.xcf.berkeley.edu Subject: Re: [Gimp-developer] how to make Gimp::Perl script work remotely? Date: Fri, 27 Sep 2002 23:56:54 +0200On Fri, Sep 27, 2002 at 02:01:57AM +0000, forest monk wrote:
not
@INC
__________________
On Sat, Sep 28, 2002 at 01:20:20AM +0000, forest monk wrote:
Thanks again for your reply. I do appreciate it. Not sure about one thing though: Do I only need the perl and gimp-perl module installed on my client box and no more software (Gtk+, GIMP) required?
In theory only gimp-perl (you can copy your perl lib dir if you are sure what you are doing). Although, while in theory it should be possible to build gimp-perl without gimp, the Makefiles don't really expect that and won't work.
You might try (as a hack, but it might work): perl Makefile.PL on the server machine, then copy the gimp-perl directory to the client "make -i -k install".
However, it's cleanest if you just install gimp + gimp-perl everywhere.
Hi Marc,
Thanks a lot for your reply. I will give it a shot.
Kindly Regards
To: forest monk
CC: gimp-developer@lists.xcf.berkeley.edu Subject: Re: [Gimp-developer] how to make Gimp::Perl script work remotely? Date: Sun, 29 Sep 2002 01:41:19 +0200On Sat, Sep 28, 2002 at 01:20:20AM +0000, forest monk wrote:
thing
client
__________________
