plug-in compilation problem
I have for some time been successful in building C plug-ins and
installing them with gimptool --install-admin plugin_name.c. The
command output echoed by this call is
/usr/bin/gcc -g -O2 -Wall -I/usr/include/gtk-1.2 -I/usr/include/glib-1.2
-I/usr/lib/glib/include -I/usr/X11R6/include -o
/usr/lib/gimp/1.2/plug-ins/plugin_name
plugin_name.c -L/usr/lib -lgimpui -lgimp -L/usr/X11R6/lib -lgtk -lgdk
-rdynamic -lgmodule -lglib -ldl -lXi -lXext -lX11 -lm
Now, I need to link an additional library into my plug-in. I built a
makefile, setting CFLAGS to the include directories called by gimptool
and LDFLAGS to gimptool's library calls (I did not yet add in the
desired additial library). When I ran the makefile against my plug-in,
I received the following error:
/usr/lib/crt1.o: In function `_start':
/usr/lib/crt1.o(.text+0x18): undefined reference to `main'
/usr/lib/libgimp.so: undefined reference to `PLUG_IN_INFO'
collect2: ld returned 1 exit status
Strange. So I tried the simplest command-line version of the compiler
call I could find:
gcc -o plugin_name `gimptool --libs --cflags` plugin_name.c
and got the same error. Worse, now, after a bit more experimentation
(changing the order of library calls in the makefile to try to match up
each -L search path with the libraries to be found there), even
results in the above error. gimptool was not edited during this process.
Any insights? My Gimp version is 1.2.1, under Red Hat Linux 6.2.
Thanks,
Cindy Huyser
