Question
Question Jean B 28 Jun 10:15
  Question syngin 28 Jun 17:48
Question Avi Bercovich 28 Jun 10:29
Jean B
2002-06-28 10:15:07 UTC (almost 23 years ago)
Question
hi,
i'am watching for a gui builder : what is gnoma, gtk, glade and why should i use them rather than xmotif or other gui builder?
for a long time, which one is the best?
regards,
jean
Avi Bercovich
2002-06-28 10:29:59 UTC (almost 23 years ago)
Question
Jean B wrote:
hi,
gnome is a large development framework targettet to bringing MS windows like desktop functionality to Unices.
gtk is a UI widget toolkit for X11, with a bunch of C helper functions in Glib.
glade is an attempt at a WYSIWYG UI-builder for the gtk toolkit.
and if you're comfortable with motif, and you don;t need to integrate your application into nome, I wouldn't know why you need to use gnome/gtk/glade over xmotif.
syngin
2002-06-28 17:48:00 UTC (almost 23 years ago)
Question
On Fri, 28 Jun 2002 03:15:07 -0500 "Jean B" sent:
hi,
GNOME -- http://www.gnome.org/
GTK+ -- http://www.gtk.org/
Glade -- Information is available at the GNOME site.
XMotif is quite old and crusty, but functional.
Try them and see. Some people swear by GTK+, others by QT.
regards,
jean
syngin-at-gimp-dot-org
