Trouble compiling Gimp 1.3.6
Trouble compiling Gimp 1.3.6 Nick Hudson 29 May 17:26
  Trouble compiling Gimp 1.3.6 Sven Neumann 30 May 01:19
   Trouble compiling Gimp 1.3.6 Nathan Carl Summers 30 May 06:44
Nick Hudson
2002-05-29 17:26:27 UTC (almost 23 years ago)
I keep getting this error when compiling the dev version of Gimp...
ar cru .libs/libgimpwidgets-1.3.a gimpwidgetsmarshal.o gimpwidgets.o gimpbutton.o gimpchainbutton.o gimpcolorarea.o gimpcolorbutton.o gimpdialog.o gimpfileselection.o gimphelpui.o gimpoffsetarea.o gimppatheditor.o gimppixmap.o gimpquerybox.o gimpsizeentry.o gimpstock.o gimpunitmenu.o ranlib .libs/libgimpwidgets-1.3.a
creating libgimpwidgets-1.3.la
(cd .libs && rm -f libgimpwidgets-1.3.la && ln -s ../libgimpwidgets-1.3.la libgimpwidgets-1.3.la) make[2]: Leaving directory `/usr/src/gimp-1.3.6/libgimpwidgets' Making all in libgimpproxy
make[2]: Entering directory `/usr/src/gimp-1.3.6/libgimpproxy' make[2]: *** No rule to make target `../tools/gimp-mkproxy', needed by `gimpobject.c'. Stop. make[2]: Leaving directory `/usr/src/gimp-1.3.6/libgimpproxy' ! Problem Detected !
make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/usr/src/gimp-1.3.6' make: *** [all-recursive-am] Error 2
Any idea on why it would be doing this? I have the most of everything compiled in except for GtkHtml2 and Mpeg.
Thanks for the help Nick Hudson
2002-05-30 01:19:53 UTC (almost 23 years ago)
Nick Hudson writes:
yes, Nathan forgot to add gimp-mkproxy to EXTRA_DIST and its missing from the tarball for that reason. As I've already explained in
http://bugzilla.gnome.org/show_bug.cgi?id=83455
you shouldn't need gimp-mkproxy since the files it generates are distributed. I wonder why the Makefile is trying to regenerate them especially since I created the tarball using make distcheck which checks that all needed files are there. As a workaround, try to touch the .c and .h files in libgimpproxy and rerun make.
Salut, Sven
Nathan Carl Summers
2002-05-30 06:44:24 UTC (almost 23 years ago)
(sound of head hitting keyboard.)
Doh! :)
Rockwalrus
