ANNOUNCE: GIMP 1.3.7
3 of 4 messages available
ANNOUNCE: GIMP 1.3.6 Sven Neumann 29 May 14:16
ANNOUNCE: GIMP 1.3.7 Sven Neumann 30 May 19:37
yfx3cwbno8l.fsf@gimp.org 07 Oct 20:21
  ANNOUNCE: GIMP 1.3.6 Robert L Krawitz 30 May 13:26
2002-05-29 14:16:10 UTC (almost 23 years ago)
the 1.3 saga continues and episode 6 just appeared on
ftp://ftp.gimp.org/pub/gimp/v1.3/v1.3.6/
Please don't beat our new disk too hard and try one of the mirrors instead:
http://www.gimp.org/download.html
This is a development version that might crash any second, so please save often and don't use it for real work. However we believe that stability and useability improved a lot so you might want to give this version a try.
This release depends on the following libraries (or newer versions):
glib 2.0.0 pango 1.0.0 (with FT2 support)
atk 1.0.0
gtk+ 2.0.0
libart 2.3.8
A couple of extra libraries are required for some of the plug-ins. You know that already, so we are only going to list the new dependencies:
gimp-print 4.2.0 for print support gtkhtml2 1.99.5 for the help browser
Overview of Changes in GIMP 1.3.6 =================================
- Support tile cache > 4GB on machines with 64bit long integers [Sven] - Added support for large files (> 2GB) [Sven] - Cleaned up configure, updated to autoconf-2.52 [Sven] - Temporary switch to the Move tool when Space is pressed [Mitch] - More cleanup of display code [Mitch] - Added mnemonics to lots of plug-ins and fixed some bugs [Maurits Rijk] - Added new PDB function gimp_image_get_name and corrected behaviour of gimp_image_get_filename [Yosh, Sven] - Navigation dialog redone as a dockable [Mitch] - Updated print plug-in to new version and depend on libgimpprint [Sven] - Generalized and improved the new config framework; use it for parasites, documents and devices [Mitch, Sven] - Started to port the help browser to GtkHtml2 [Sven] - Finished implementation of the Thumbnail Managing Standard [Mitch, Sven] - Improved Open dialog using the new thumbnails [Mitch, Sven] - Use UTF-8 encoded URIs where we used to use filenames [Mitch] - Plug-in fixes [Iccii]
- Added shortcuts to crop layer or image to selection boundary [Mitch] - Changes for build on Win32 [Tor Lillqvist, Hans Breuer] - Started framework for tools loaded as modules or plug-ins [Nathan] - Lots of bugfixes
- More stuff not mentioned here (see the ChangeLog)
Other contributors: Zbigniew Chyla, OEyvind Kolaas, Nick Lamb, David Monniaux, Raphael Quinet, Jakub Steiner, Simon Budig
Happy GIMPing,
Sven Neumann, Michael Natterer
Robert L Krawitz
2002-05-30 13:26:01 UTC (almost 23 years ago)
Date: 29 May 2002 14:16:10 +0200
Note that any 4.2 version of Gimp-print will work.
2002-05-30 19:37:52 UTC (almost 23 years ago)
it turned out that the 1.3.6 tarball that was released yesterday has some flaws so we decided to release 1.3.7. The new tarball as well as a patch to upgrade from 1.3.6 are available from
ftp://ftp.gimp.org/pub/gimp/v1.3/v1.3.7/
or one from one of the mirrors:
The changes from version 1.3.6 are a couple of build fixes as well as at least one major bug fix. So even if you succeeded to build 1.3.6 you should update to 1.3.7.
Happy GIMPing, Sven
