siod (Script-Fu) string-length limitations
siod (Script-Fu) string-length limitations Jeff Trefftzs 12 Apr 21:04
  siod (Script-Fu) string-length limitations Nathan C Summers 12 Apr 21:46
  siod (Script-Fu) string-length limitations Sven Neumann 12 Apr 21:46
Jeff Trefftzs
2002-04-12 21:04:39 UTC (about 23 years ago)
I've been experimenting with building a L-systems script-fu, but have hit a seemingly insuperable obstacle. It seems that there's a built-in limitation in siod that prevents strings from exceeding somewhere between 4050 and 4094 bytes. Since L-systems are basically string-rewriting systems, with the strings getting longer at each rewrite, this arbitrarily low limit is a real PITA. Indeed, it's a show-stopper.
Despite the known annoyances of trying to do string handling in any lisp-like language, I started out using the scheme script-fu instead of perl in hopes of making the resulting script usable on windoze machines as well as Linux boxes. But when I finally got things working, the interpreter just dies/hangs when the strings start getting too long. There are no error messages, no core dumps, no segfaults -- it just stops, silently.
So my questions are:
(1) Is the specific version of siod that the GIMP uses documented anywhere?
(2) Is there a sensible workaround for the (apparently) limited string length?
(3) Is there a way to extend the GIMP's version of siod's capabilities to allow strings of arbitrary (large, very large) length in 1.4? (Or, even better, in 1.2.x?)
Nathan C Summers
2002-04-12 21:46:42 UTC (about 23 years ago)
Have you tried using lists of single charactors instead? Note quite as memory efficient, sure, but you can make a list as big as available memory.
Rockwalrus
2002-04-12 21:46:48 UTC (about 23 years ago)
Jeff Trefftzs writes:
I'd like to replace our scheme implementation with something more advanced. The main reason is that I hope to improve error reporting and thus script debugging. Guile comes to mind but I don't have any experience with Scheme engines and I would love to see someone else taking the job of fixing Script-Fu for 1.4.
Salut, Sven
