erase-rows.scm patch
8 of 8 messages available
erase-rows.scm patch Rory Hunter 08 Apr 16:18
  erase-rows.scm patch Sven Neumann 09 Apr 13:21
   erase-rows.scm patch Branko Collin 09 Apr 16:19
    erase-rows.scm patch Sven Neumann 09 Apr 16:42
     erase-rows.scm patch Branko Collin 09 Apr 17:05
      erase-rows.scm patch Sven Neumann 09 Apr 17:05
       erase-rows.scm patch Branko Collin 09 Apr 17:26
      erase-rows.scm patch Carol Spears 09 Apr 20:49
Rory Hunter
2002-04-08 16:18:46 UTC (about 23 years ago)
(My apologies if this is the wrong forum for this message.)
I've edited the "Erase every other row" script-fu so that the size of the rows can be changed. I can't find a contact address for the original author, so I've attached a patch.
Thanks for your time,
-- Rory Hunter "Yes, but most people don't attack their boxes with the same cavalier abandon you do."
-- Said when modding my box [fenriz.org]
--- erase-rows.scm Mon Apr 8 15:10:31 2002 +++ erase-n-rows.scm Mon Apr 8 15:09:41 2002 @@ -1,19 +1,33 @@
-(define (script-fu-erase-rows img drawable orientation which type) +;; roryh@fenriz.org Mon Apr 8 14:35:49 BST 2002 +;; Added size parameter to control size of rows / colums +(define (script-fu-erase-rows img drawable orientation which type size_raw) (let* ((width (car (gimp-drawable-width drawable))) - (height (car (gimp-drawable-height drawable)))) + (height (car (gimp-drawable-height drawable))) + (size (if (= orientation 0)
+ (if (> size_raw height) height size_raw) + (if (> size_raw width) width size_raw)))) (gimp-undo-push-group-start img) (letrec ((loop (lambda (i max)
(if (< i max)
(begin
- (gimp-rect-select img 0 i width 1 REPLACE FALSE 0) - (gimp-rect-select img i 0 1 height REPLACE FALSE 0)) + ;; roryh@fenriz.org Mon Apr 8 14:33:47 BST 2002 + ;; Changed the code here to use a variable size + ;; for row / column width / height. + (gimp-rect-select img 0 i width size REPLACE FALSE 0) + (gimp-rect-select img i 0 size height REPLACE FALSE 0)) + ;; roryh@fenriz.org Mon Apr 8 14:55:24 BST 2002 + ;; Handle extra operation
(if (= type 0)
(gimp-edit-clear drawable) - (gimp-edit-fill drawable BG-IMAGE-FILL)) - (loop (+ i 2) max))))))
+ (if (= type 1)
+ (gimp-edit-fill drawable FG-IMAGE-FILL) + (gimp-edit-fill drawable BG-IMAGE-FILL))) + ;; roryh@fenriz.org Mon Apr 8 14:35:24 BST 2002 + ;; Changed loop increment to variable + (loop (+ i (* 2 size)) max)))))) (loop (if (= which 0)
0
1)
height
@@ -21,17 +35,21 @@
(gimp-selection-none img)
(gimp-undo-push-group-end img)
(gimp-displays-flush)))
(script-fu-register "script-fu-erase-rows" - _"/Script-Fu/Alchemy/Erase every other Row..." - "Erase every other row/column with the background color" - "Federico Mena Quintero"
- "June 1997"
+ _"/Script-Fu/Alchemy/Erase Rows..." + "Erase every n rows/columns with the background color" + "Federico Mena Quintero / Rory Hunter" + "Federico Mena Quintero / Rory Hunter" + "June 1997 / April 2002"
"RGB* GRAY* INDEXED*"
SF-IMAGE "Image" 0
SF-DRAWABLE "Drawable" 0
SF-OPTION _"Rows/Cols" '(_"Rows" _"Columns") SF-OPTION _"Even/Odd" '(_"Even" _"Odd") - SF-OPTION _"Erase/Fill" '(_"Erase" _"Fill with BG")) + ;; roryh@fenriz.org Mon Apr 8 14:55:54 BST 2002 + ;; Extra opertion - fill with FG colour. + SF-OPTION _"Erase/Fill" '(_"Erase" _"Fill with FG" _"Fill with BG") + ;; Added option for size.
+ SF-ADJUSTMENT _"Row Size" '(1 1 100 1 1 0 1))
2002-04-09 13:21:58 UTC (about 23 years ago)
Rory Hunter writes:
could you please file a bug-report with severity set to "enhancement" on http://bugzilla.gnome.org/ and attach your patch to the bug-report. This will assure that we don't forget your patch.
Salut, Sven
Branko Collin
2002-04-09 16:19:46 UTC (about 23 years ago)
On 9 Apr 2002, at 13:21, Sven Neumann wrote:
Rory Hunter writes:
What was wrong with my patch, which implemented the same and more?
2002-04-09 16:42:30 UTC (about 23 years ago)
"Branko Collin" writes:
probably nothing... Could you help my leaky brain by pointing me to the respective bugzilla number? Or did we already apply the patch?
Salut, Sven
Branko Collin
2002-04-09 17:05:32 UTC (about 23 years ago)
I did not submit it to Bugzilla, because nobody told me to. Instead I sent it to the list on May 19 last year, in a thread called Gallery Maker.
Since nobody told me otherwise, I assumed this was the way to send in patches (and if memory serves me, this is the way people sent in patches back then).
2002-04-09 17:05:45 UTC (about 23 years ago)
sure. That's probably the reason why so many patches got lost back then. So, could you please attach your patch to #78180, thanks.
Salut, Sven
Branko Collin
2002-04-09 17:26:49 UTC (about 23 years ago)
Will do, thanks.
Carol Spears
2002-04-09 20:49:53 UTC (about 23 years ago)
On 2002-04-09 at 1705.32 +0200, Branko Collin typed this mail:
in defense of this list as a method to introduce patches and plug-ins and such, branko, your mail was very difficult to keep up with last year.
