eps images that won't load
5 of 6 messages available
eps images that won't load Peter Kirchgessner 06 Apr 21:57
  eps images that won't load Carol Spears 06 Apr 22:57
eps images that won't load Peter Kirchgessner 07 Apr 18:07
286080883@spray.se 07 Oct 20:21
  eps images that won't load Carol Spears 06 Apr 20:35
   eps images that won't load Branko Collin 06 Apr 22:55
Carol Spears
2002-04-06 20:35:58 UTC (about 23 years ago)
here is a question from the user list. since i have used gimp to work with eps files before, i got one of the images and tried to open it. my gimp-1.2 failed also. any ideas?
the image i downloaded and unzipped is located here http://carol.gimp.org/files/TORG_illustration.eps
thanks, carol
On 2002-04-05 at 1808.26 +0000, gurra16@spray.se typed this mail:
How come GIMP fails to load these images? (Note they are zip-ed) http://www.liljeholmstorget.nu/press.html
Gustav Persson
Peter Kirchgessner
2002-04-06 21:57:42 UTC (about 23 years ago)
Hi Carol,
EPS-files require an additional showpage command submitted to ghostscript. This is usually done by the ps-plugin. But these binary PostScript files (I have never seen before) are not recognized as EPS-files. The plug-in is not looking at the extension. If you or Gustav are working with Linux, you can use a workaround. Create a file /tmp/gs_eps with the following content:
#!/bin/sh args=`echo $* | sed -e 's/eps -c quit/eps -c showpage -c quit/'` exec gs $args
(Note the different ` and ´). Make it executable:
chmod 755 /tmp/gs_eps
Set an environment variable in the bash:
export GS_PROG=/tmp/gs_eps
and start gimp from that shell:
gimp TORG_illustration.eps
For Windows I don't know an appropriate workaround.
Sincerely
Peter
thanks, carol
Gustav Persson
Gimp-developer@lists.xcf.berkeley.edu http://lists.xcf.berkeley.edu/mailman/listinfo/gimp-developer
Branko Collin
2002-04-06 22:55:01 UTC (about 23 years ago)
Just as well, I am not sure a young girl like you should read words like 'butiker' and 'torget'. ;-)
Strangely enough, gsview/ghostscript is able to open the image. (I thought GIMP used ghostscript internally?)
Carol Spears
2002-04-06 22:57:14 UTC (about 23 years ago)
On 2002-04-06 at 2157.42 +0200, Peter Kirchgessner typed this mail:
Hi Carol,
thank you for this. i am going to forward it to the list, as there seems to be some confusion there about gimp and postscript. it should go online somewhere, i think ....
thanks again, carol
ps. branko, i have little notes to myself that are old than you ....
Peter Kirchgessner
2002-04-07 18:07:15 UTC (about 23 years ago)
the corrected plug-in is available in source and executable for Linux/i386 at http://www.kirchgessner.net
Sincerely
Peter
Hi Carol,
thanks again, carol
