docs.gimp.org - restarted automated builds for the 2.10 (master) branch and the web site itself
docs.gimp.org - restarted automated builds for the 2.10 (master) branch and the web site itself Michael Schumacher 22 Jun 15:21
2019-06-22 15:21:14 UTC (almost 6 years ago)
I had a look at the automated builds on docs.gimp.org recently and found that the build for 2.10 content - that is https://docs.gimp.org/2.10/en/ and the other language versions - had been blocked by a git checkout problem for some time.
This has been corrected and the build is restarted, so the current content from the gimp-help master branch should be present now.
I've reschedules the builds to happen at at 00:23, 08:23 and 16:23 GMT every day. They write a short log file to https://docs.gimp.org/2.10/build.log
I've also extended the build to the actual website contents - that is the index.html and some other pages.
This build runs every 10 minutes and rebuilds only if there are changes present. Its log file is at https://docs.gimp.org/web-build.log
https://docs.gimp.org will now properly direct visitors to the 2.10 online help instead of the 2.8 version, and 2.10 does have up-to-date content.
P.S. I've also run make dist manually and got a tarball out of this - it's at https://download.gimp.org/pub/gimp/help/gimp-help-2.10.0.tar.bz2
Any feedback to whether this tarball is suitable for distro and/or installer packages would be helpful.
-- Regards,
