BABL constructors speedup patch
| BABL constructors speedup patch | Jan Heller | 29 Mar 17:57 |
| BABL constructors speedup patch | Sven Neumann | 29 Mar 20:04 |
| BABL constructors speedup patch | Jan Heller | 31 Mar 00:29 |
| BABL constructors speedup patch | Sven Neumann | 31 Mar 08:27 |
Here is an another patch I came up with while playing with BABL code. It concerns constructors of the BABL classes. The original code prepares the whole instance of a class before trying to insert it into the BABL database. The insertion might fail in case there is an instance of the same name already present in the database. This is a bit wasteful, so the patch tries to test the preexistent instance as soon as possible.
It showed up that this brought a considerable speedup. It speeds babl_fish_path_dhtml by up to 9%. Speedup of everyday BABL usage won't be as significant, but measurable nonetheless.
I sneaked two minor typo fixups into the patch as well.
Regards, Jan
Index: babl/babl-model.c
--- babl/babl-model.c (revision 297)
+++ babl/babl-model.c (working copy)
@@ -161,14 +161,24 @@ babl_model_new (void *first_argument,
va_end (varg);
- babl = model_new (create_name (name, components, component), id, components, component);
+ name = create_name (name, components, component);
- Babl *ret = babl_db_insert (db, babl);
- if (ret != babl)
- babl_free (babl);
- return ret;
+ babl = babl_db_exist (db, id, name);
+ if (babl)
+ /* There is an instance already registered by the required id/name,
+ * returning the preexistent one instead.
+ return babl;
+ babl = model_new (name, id, components, component);
+ /* Since there is not an already registered instance by the required
+ * id/name, inserting newly created class into database.
+ babl_db_insert (db, babl);
+ return babl;
Index: babl/babl-fish-path.c
--- babl/babl-fish-path.c (revision 297)
+++ babl/babl-fish-path.c (working copy)
@@ -284,6 +284,15 @@ babl_fish_path (const Babl *source,
char *name = create_name (source, destination, 1);
BablConversion *temp_chain[BABL_HARD_MAX_PATH_LENGTH];
+ babl = babl_db_exist_by_name (babl_fish_db (), name);
+ if (babl)
+ /* There is an instance already registered by the required name,
+ return babl;
babl_assert (BABL_IS_BABL (source));
babl_assert (BABL_IS_BABL (destination));
@@ -329,12 +338,11 @@ babl_fish_path (const Babl *source,
return NULL;
- Babl *ret = babl_db_insert (babl_fish_db (), babl);
- if (ret != babl)
- babl_free (babl);
- return ret;
+ * name, inserting newly created class into database.
+ babl_db_insert (babl_fish_db (), babl);
+ return babl;
static long
Index: babl/babl-format.c
--- babl/babl-format.c (revision 297)
+++ babl/babl-format.c (working copy)
@@ -45,24 +45,25 @@ format_new (const char *name,
Babl *babl;
- int i;
- /* i is desintation position */
- for (i = 0; i < model->components; i++)
- int j;
- for (j = 0; j < components; j++)
- if (component[j] == model->component[i])
- goto component_found;
- babl_fatal ("matching source component for %s in model %s not found",
- model->component[i]->instance.name, model->instance.name);
-component_found:
+ /* i is desintation position */
+ int i, j, component_found = 0;
+ for (i = 0; i < model->components; i++)
+ for (j = 0; j < components; j++)
+ if (component[j] == model->component[i])
+ component_found = 1;
+ break;
+ if (!component_found)
+ component_found = 0;
+ babl_fatal ("matching source component for %s in model %s not found",
+ model->component[i]->instance.name, model->instance.name);
/* allocate all memory in one chunk */
babl = babl_malloc (sizeof (BablFormat) +
@@ -295,17 +296,28 @@ babl_format_new (void *first_arg,
va_end (varg);
- babl = format_new (name ? name : create_name (model, components, component, type),
+ if (!name)
+ name = create_name (model, components, component, type);
+ if (babl)
+ return babl;
+ babl = format_new (name,
id,
planar, components, model,
component, sampling, type);
- if (ret != babl)
- babl_free (babl);
- return ret;
+ return babl;
int
Index: babl/babl-component.c
--- babl/babl-component.c (revision 297)
+++ babl/babl-component.c (working copy)
@@ -109,14 +109,22 @@ babl_component_new (void *first_arg,
va_end (varg);
+ babl = babl_db_exist (db, id, first_arg);
+ if (babl)
+ return babl;
babl = component_new (first_arg, id, luma, chroma, alpha);
- if (ret != babl)
- babl_free (babl);
- return ret;
+ return babl;
BABL_CLASS_TEMPLATE (component)
Index: babl/babl-extension.c
--- babl/babl-extension.c (revision 297)
+++ babl/babl-extension.c (working copy)
@@ -184,7 +184,7 @@ babl_extension_load (const char *path)
init = dlsym (dl_handle, "init");
if (!init)
- babl_log ("\n\tint babl_extension_init() function not found in extenstion '%s'", path);
+ babl_log ("\n\tint babl_extension_init() function not found in extension '%s'", path);
dlclose (dl_handle);
return load_failed (babl);
@@ -202,7 +202,8 @@ babl_extension_load (const char *path)
- if (babl_db_insert (db, babl) == babl)
+ if (babl == babl_db_exist_by_name (db, path))
babl_set_extender (NULL);
return babl;
Index: babl/babl-fish-simple.c
--- babl/babl-fish-simple.c (revision 297)
+++ babl/babl-fish-simple.c (working copy)
@@ -34,6 +34,15 @@ babl_fish_simple (BablConversion *conver
name = create_name (conversion);
+ if (babl)
+ return babl;
babl = babl_malloc (sizeof (BablFishSimple) +
strlen (name) + 1);
babl->class_type = BABL_FISH_SIMPLE;
@@ -50,10 +59,9 @@ babl_fish_simple (BablConversion *conver
reference, and babl fish reference only requests clean
conversions */
- if (ret != babl)
- babl_free (babl);
- return ret;
+ return babl;
Index: babl/babl-type.c
--- babl/babl-type.c (revision 297)
+++ babl/babl-type.c (working copy)
@@ -128,14 +128,22 @@ babl_type_new (void *first_arg,
va_end (varg);
+ if (babl)
+ return babl;
babl = type_new (first_arg, id, bits);
- if (ret != babl)
- babl_free (babl);
- return ret;
+ return babl;
Index: babl/babl-conversion.c
--- babl/babl-conversion.c (revision 297)
+++ babl/babl-conversion.c (working copy)
@@ -79,7 +79,7 @@ conversion_new (const char *name,
else if (planar)
- babl_fatal ("planar conversions not supported for %ssupported",
+ babl_fatal ("planar conversions not supported for %s",
babl_class_name (source->class_type));
break;
@@ -257,18 +257,26 @@ babl_conversion_new (void *first_arg,
type = BABL_CONVERSION_PLANAR;
- babl = conversion_new (create_name (source, destination, type),
- id, source, destination, linear, plane, planar);
- if (ret != babl)
- babl_free (babl);
- else
- babl_add_ptr_to_list ((void ***) ((Babl *) &(source->type.from)), babl);
- return ret;
+ char * name = create_name (source, destination, type);
+ if (babl)
+ return babl;
+ babl = conversion_new (name, id, source, destination, linear, plane, planar);
+ babl_add_ptr_to_list ((void ***) ((Babl *) &(source->type.from)), babl);
+ return babl;
static long
Index: babl/babl-db.c
--- babl/babl-db.c (revision 297)
+++ babl/babl-db.c (working copy)
@@ -94,12 +94,6 @@ Babl *
babl_db_insert (BablDb *db,
Babl *item)
- Babl *found = babl_db_exist (db, item->instance.id, item->instance.name);
- if (found)
- return found;
if (item->instance.id)
babl_hash_table_insert (db->id_hash, item);
babl_hash_table_insert (db->name_hash, item);
Index: babl/babl-fish-reference.c
--- babl/babl-fish-reference.c (revision 297)
+++ babl/babl-fish-reference.c (working copy)
@@ -51,6 +51,15 @@ babl_fish_reference (const Babl *source,
Babl *babl = NULL;
+ if (babl)
+ return babl;
@@ -71,12 +80,12 @@ babl_fish_reference (const Babl *source,
babl->fish.error = 0.0; /* assuming the provided reference conversions for types
and models are as exact as possible
- if (ret != babl)
- babl_free (babl);
- return ret;
+ return babl;
Very nice. I have committed this change to SVN.
BTW, wasn't there some additional changes needed after your last patch? If I remember correctly, some lists still need to be ported to the new list API. Is that correct?
Hi
That is correct. I will definitely port the rest of the code to the new API, I'm just contemplating the best course of action. There are other related changes I would want to make and I was thinking I'd make them all at once.
Regards, Jan
The less changes in one step, the better. This will make it easier for us to review the changes. Also in case that something breaks, it makes it a lot easier to isolate the change that caused the problem. So, if possible, please try to create many small patches instead of one large one. Thanks.
