the blur/smudge was better in 2.8
the blur/smudge was better in 2.8 Natalie Baldwin via gimp-developer-list 20 Jun 05:12
  the blur/smudge was better in 2.8 Ell via gimp-developer-list 22 Jun 16:55
   the blur/smudge was better in 2.8 Ell via gimp-developer-list 19 Jul 18:55
2019-06-20 05:12:32 UTC (over 6 years ago)
I've redownloaded version 2.8 because i've found no way to emulate the mathematical precision that the blur/smudge tools give me. The gradient tool with perceptual RGB works almost as expected, somehow the blue value goes up even though i'm trying to gradient between pure red and pure green. Making a transition with blur/smudge from 255-0-0 to 0-255-0 (red to green) i do not expect to get any colours where red+green > 255. I expect to find 254-1-0 followed by 253-2-0 followed by 252-3-0 etc. This feature is extremely important to me because of a shader i wrote that reads colour values mathematically. So, if i get a vote, please reintroduce the old way to blur. Here is an image with blur and smudge examples. The top half is what i desire, it's using blur/smudge from 2.8 resulting in colour values where R+G+B is very close to 255. The bottom half is far too yellow, those colour values are close to 200-200 which is far greater than the 255 i require.
https://gyazo.com/4bf04c204f6abe42524d1dabe37b0a22
2019-06-22 16:55:54 UTC (over 6 years ago)
On June 20, 2019 8:12:32 AM GMT+02:00, Natalie Baldwin via gimp-developer-list wrote:
to blur.
In 2.10, many operations, especially ones involving color blending, transitioned from working in perceptual RGB, to linear RGB. This is the physically-correct way to blend colors, as, in perceptual RGB, the component intensities are compressed using a nonlinear gamma function. In other words, this change is intentional, and is generally the Right Thing to do.
That being said, there are still valid reasons to want to keep working in perceptual RGB, as in your case. Unfortunately, while some parts of GIMP provide this choice, others (like the smudge and blur tools) don't: it's a balancing act between allowing enough control, while not cluttering the UI with too many options, which we haven't fully nailed down yet. That's not to say we don't want to get there eventually, just that we don't have a general solution that feels quite *right* yet.
While there are workarounds for working perceptually in 2.10, even when GIMP doesn't provide this option otherwise, they're so terrible that I'd rather not mention them :)
Lastly, just to reiterate, the smudge and blur tools *do* still have the properties you're looking for, they just apply to the *linear* component values, rather than to the perceptual ones (which can be checked by converting the image precision to 32-bit linear float, and using the color picker tool in "pixel" mode). So, another option is to switch your shaders from working in perceptual RGB to linear RGB, if that's applicable.
The gradient
Oof, good catch! That's a bug. You can take care of that by disabling dithering in the gradient-tool options, but it shouldn't happen with dithering enabled either.
-- Ell
Sent from my Android device with K-9 Mail. Please excuse my brevity.
2019-07-19 18:55:17 UTC (over 6 years ago)
The gradient
This is now fixed in master and gimp-2-10 by e22fcc8942963d7a1cfca57965d0385f073d5b3a and 91c20c783abd73849457ea586f760a7ec44d1f3c, resp.
-- Ell
