A plea for a tiny feature
On Tue, 2019-04-16 at 11:54 +0200, Helmut Jarausch via gimp-developer-
list wrote:
(/usr/lib64/gimp/2.0/plug-ins/script-fu/script-fu) is installing
procedure
"script-fu-selection-to-anim-image" with a full menu path
"/Filters/Animation/Animators/Selection to AnimImage..."
as menu label, this deprecated and will be an error in GIMP 3.0
It would be nice if this messages would display the name of the
script, as well.
I believe this was added in the development branch (i made a patch to
do it, and i think Mitch improved on it). Assuming by name of the
script you mean filename.
However,
grep -r -l selection-to-anim-image ~/.gimp-2.8/
will likely get you there in the meantime.
Liam (slave ankh)
Liam Quin, https://www.delightfulcomputing.com/
Available for XML/Document/Information Architecture/XSLT/
XSL/XQuery/Web/Text Processing/A11Y training, work & consulting.
Web slave for vintage clipart http://www.fromoldbooks.org/
