Gtk4
7 of 7 messages available
Gtk4 Massimo Fidanza via gimp-developer-list 13 Feb 00:24
  Gtk4 Tobias Jakobs via gimp-developer-list 13 Feb 10:32
   Gtk4 Elle Stone 13 Feb 11:41
    Gtk4 Alexandre Prokoudine via gimp-developer-list 13 Feb 11:59
     Gtk4 Joao S. O. Bueno via gimp-developer-list 13 Feb 12:40
      Gtk4 Massimo Fidanza via gimp-developer-list 13 Feb 13:21
       Gtk4 Tobias Ellinghaus 14 Feb 09:07
2019-02-13 00:24:48 UTC (about 6 years ago)
Gtk4
Now that Gtk4 is almost done, Gimp 3 will continue target gtk+3 or will switch to Gtk4? If sticking with gtk+3 how difficult will be targeting Gtk4?
2019-02-13 10:32:02 UTC (about 6 years ago)
Gtk4
from where do you have the information it is almost done? Ff I look into this blog post I don't expect it weeks: https://blog.gtk.org/2019/02/08/report-from-the-gtk-hackfest-in-brussels/
Regards, Tobias
Am Mi., 13. Feb. 2019 um 01:25 Uhr schrieb Massimo Fidanza via gimp-developer-list :
Elle Stone
2019-02-13 11:41:14 UTC (about 6 years ago)
Gtk4
Gtk4?
Whether "almost done" means a couple of weeks or a couple of months, I'm guessing GIMP-3.0 won't be released before GTK4.0 is released, yes? So Massimo Fidanza's questions still are interesting questions, that I've also wondered about.
I find the release cycle described in these two posts very confusing:
https://blogs.gnome.org/desrt/2016/06/13/gtk-4-0-is-not-gtk-4/ https://blogs.gnome.org/desrt/2016/06/14/gtk-5-0-is-not-gtk-5/
Quoting from the first post, what does this mean?
Meanwhile, Gtk 4.0 will not be the final stable API of what we would call “Gtk 4”. Each 6 months, the new release (Gtk 4.2, Gtk 4.4, Gtk 4.6) will break API and ABI vs. the release that came before it. These incompatible minor versions will not be fully parallel installable; they will use the same pkg-config name and the same header file directory. We will, of course, bump the soname with each new incompatible release — you will be able to run Gtk 4.0 apps alongside Gtk 4.2 and 4.4 apps, but you won’t be able to build them on the same system.
In particular, what does the part about "you will be able to run GTK4.0 apps alongside Gtk 4.2 and 4.4 apps, but you won't be able to build them on the same system" mean?
I recall seeing a similar statement about GTK3, that a software package has to target a specific version of GTK3. So how does the new GTK development cycle actuallly affect GIMP development?
I think GIMP-3.0 targets a particular version of GTK3?
Will GIMP-4.0 branch be started when GTK-4.6 is released?
Will the port from GTK3 to GTK4 be as onerous as the port from GTK2 to GTK3?
Best regards, Elle
2019-02-13 11:59:41 UTC (about 6 years ago)
Gtk4
https://blog.gtk.org/2019/02/08/report-from-the-gtk-hackfest-in-brussels/ appears to outline a number of changes that will absolutely affect GIMP. E.g. I'm unsure if the proposed constraint -based layout system will replace the old boxes or be available next to it. But if it will, updating the UI will take quite a while.
Alex
2019-02-13 12:40:55 UTC (about 6 years ago)
Gtk4
So, from the post entitled "GTK 4.0 is not GTK 4", we read, with all letters:
"""In this way, “Gtk 4.0” is not “Gtk 4”. “Gtk 4.0” is the first raw version of what will eventually grow into “Gtk 4”, sometime around Gtk 4.6 (18 months later)."""
So, it is actually not ready "a couple of weeks" from now.
On Wed, 13 Feb 2019 at 10:00, Alexandre Prokoudine via gimp-developer-list < gimp-developer-list@gnome.org> wrote:
GTK3?
Alex _______________________________________________ gimp-developer-list mailing list
2019-02-13 13:21:47 UTC (about 6 years ago)
Gtk4
Let me say that I don't see a great reaction in the comment of this blog post. To me this versionig schema sounds very overcomplicated and semantic versioning (http://semver.org/) looks much better, but I'm not the developer of GTK. So if Gimp 3 will be released before about 20 months from now, tageting GTK+3 looks fine, otherwise considering GTK4 could be better. But how much work need to be done to port to GTK4? Are there tools that can automate the porting?
Il giorno mer 13 feb 2019 alle ore 13:41 Joao S. O. Bueno via gimp-developer-list ha scritto:
GTK3?
Tobias Ellinghaus
2019-02-14 09:07:26 UTC (about 6 years ago)
Gtk4
Am Mittwoch, 13. Februar 2019, 14:21:47 CET schrieb Massimo Fidanza via gimp- developer-list:
From the experience with GTK3 and the constant API changes I wouldn't even start porting any software to a new GTK flavour until the API is promised to be stable. Otherwise it is a constant chase and no fun at all.
Tobias
