Unable to build GIMP-2.99 on Debian Sid
Unable to build GIMP-2.99 on Debian Sid Elle Stone 29 Jan 19:00
  Unable to build GIMP-2.99 on Debian Sid Elle Stone 29 Jan 19:51
Elle Stone
2019-01-29 19:00:45 UTC (about 6 years ago)
GIMP-2.99 builds just fine on Gentoo. But it won't build on a fresh install of Debian Sid. It also wouldn't build on Debian testing
The current error in building (having solved several previous "won't build" errors) seems to be with making the symbolic icons. I don't have a clue what to do next.
Here's the terminal output:
$ make -j4 > /dev/null Unescaped left brace in regex is deprecated here (and will be fatal in Perl 5.32), passed through in regex; marked by < (([^*]|\*(?!/))*)
>\s*\*/)?
/ at enumgen.pl line 218.
Name "Gimp::CodeGen::util::FILE_EXT" used only once: possible typo at enumgen.pl line 34.
Name "Gimp::CodeGen::enums::enums" used only once: possible typo at enumcode.pl line 30.
Name "Gimp::CodeGen::util::FILE_EXT" used only once: possible typo at enumcode.pl line 33.
Use of uninitialized value in pattern match (m//) at enumcode.pl line 71. Can't load file: Unrecognized image file format Can't load file: Unrecognized image file format make[3]: *** [Makefile:2363: 64/dialog-question-symbolic.symbolic.png] Error 1
make[3]: *** Waiting for unfinished jobs.... make[3]: *** [Makefile:2363: 64/dialog-warning-symbolic.symbolic.png] Error 1
64/dialog-information-symbolic.symbolic.png] Error 1 Can't load file: Unrecognized image file format make[3]: *** [Makefile:2363: 64/dialog-error-symbolic.symbolic.png] Error 1 make[2]: *** [Makefile:719: all-recursive] Error 1 make[1]: *** [Makefile:853: all-recursive] Error 1 make: *** [Makefile:754: all] Error 2
https://ninedegreesbelow.com
Color management and free/libre photography
Elle Stone
2019-01-29 19:51:11 UTC (about 6 years ago)
            >\s*\*/)?
The problem with building on Debian (but not on Gentoo or OpenSUSE) turned out to be this:
https://www.wiki.gimp.org/wiki/Hacking:Problems_and_solutions#GIMP_build_fails_with_message_.27Couldn.27t_recognize_the_image_file_format_for_file_..2Fcursor-bad.png.27
So it's not a problem with the Symbolic icons, and GIMP did finally build successfully.
Best,
Elle
