Options in blur filters
Options in blur filters Julien Hardelin 08 Nov 06:14
  Options in blur filters Julien Hardelin 14 Nov 06:35
   Options in blur filters Marco Ciampa via gimp-docs-list 14 Nov 09:19
    Options in blur filters Julien Hardelin 14 Nov 19:40
Julien Hardelin
2018-11-08 06:14:53 UTC (over 6 years ago)
Hi all,
In several blur filters, we have the options "Use the selection as input" and "Use the entire layer as input".
I don't understand well these options. If I test "Use the entire layer as input" in Pixelize with a selection, I can see some slight differences in result, but I don't find, in result, colors that are in the layer outside the selection.
In my mind, in Pixelize, the color of a pixel is the mean of colors in the square it belongs to, and "use the entire layer as input" looks weird.
Can you enlighten me on this point?
Julien
Julien Hardelin
2018-11-14 06:35:55 UTC (over 6 years ago)
No answer to my question :-(
Nobody knows how "Use the the _entire_ layer as input" works?
Julien
Le 08/11/2018 à 07:14, Julien Hardelin a écrit :
Hi all,
Julien
_______________________________________________ gimp-docs-list mailing list
gimp-docs-list@gnome.org
2018-11-14 09:19:00 UTC (over 6 years ago)
Julien
Why not try to post it also on the -dev ml?
Marco Ciampa
I know a joke about UDP, but you might not get it.
 GNU/Linux User #78271
 FSFE fellow #364
Julien Hardelin
2018-11-14 19:40:34 UTC (over 6 years ago)
Eureka!
"entire layer" does not mean all the pixels of the layer, but only selection + the rest of the layer. Actually, this option works on selection border and uses near pixels in the rest of the layer to create the color of border squares, probably to create a gradual transition between the selection and the rest of the layer.
Julien
