gimp-doc and its web html
7 of 7 messages available
gimp-doc and its web html Marco Ciampa via gimp-web-list 10 Sep 16:53
  gimp-doc and its web html Pat David via gimp-web-list 11 Sep 20:29
   gimp-doc and its web html Marco Ciampa via gimp-docs-list 12 Sep 07:13
    gimp-doc and its web html Pat David via gimp-docs-list 12 Sep 14:13
     gimp-doc and its web html Sam Gleske via gimp-docs-list 12 Sep 23:15
      gimp-doc and its web html Pat David via gimp-docs-list 12 Sep 23:18
       gimp-doc and its web html Sam Gleske via gimp-docs-list 12 Sep 23:20
2018-09-10 16:53:57 UTC (over 6 years ago)
Hi devs,
I have a couple of wishes. I would like to have:
1) a clear reference to the old stable docs on the /docs/ page. I mean, now, when you click on some nationalized or on the english reference docs, from the /docs/ page the browser go to:
https://docs.gimp.org/2.10/en/
and from that, a skilled user can change the version number in the browser address and be able to read also some older docs like:
https://docs.gimp.org/2.8/en/
This is IMHO very useful but it would be much more useful if there were some explicit links to this older manual pages. Is it possible to add those links to the main /docs/ page?
2) is it possible to add also a /docs/devel/ link or something like that to the /docs/ page to enable users to consult also the (on going) development pages? That would come very useful to enable the review of the documents by some other people - people like voluteers willing to help the revision of the translations or of the reference docs.
TIA
Best regards,
Marco Ciampa
I know a joke about UDP, but you might not get it.
 GNU/Linux User #78271
 FSFE fellow #364
2018-09-11 20:29:15 UTC (over 6 years ago)
Howdy!
To clarify, you want a link to the old docs as well, on the page https://www.gimp.org/docs ?
Would something like
* English (2.8)
work, (where there is a link for "2.8" to the old versions)?
Where should the /docs/devel/ link go to, exactly? Where are the on-going development pages located (url)?
https://patdavid.net
GPG: 66D1 7CA6 8088 4874 946D  18BD 67C7 6219 89E9 57AC
2018-09-12 07:13:55 UTC (over 6 years ago)
On Tue, Sep 11, 2018 at 03:29:15PM -0500, Pat David wrote:
Howdy!
Yeah I think it could be useful ... I can try to propose a patch to the gimp-web repo but I am not a very good boot web designer... but I can try...
* English (2.8)
precisely
Look at this (old) page for an example:
https://docs.gimp.org/download.html
(see that there are even the older docs, 2.6 or even 2.4 for example). Kept for historical reasons?
This is the problem. I was not able to figure out the URL (if there is any).
If there was an open dir like it is for this project (KiCad) for instance:
http://docs.kicad-pcb.org/
it would be much easier to search through the docs version without the need to update the web page at every new version...
if you try with gimp you get this old page:
So first and foremost we should ask a web developer where it is. If there is none, I would ask gently the developers to create one with an CI server connected just to render the on-going documentation and translation efforts continuously. Is it asking too much? Hope not! :-)
Marco Ciampa
 FSFE fellow #364
2018-09-12 14:13:31 UTC (over 6 years ago)
* English (2.8)
precisely
Actually, since we have that page I think it might be best to include a link at the end of the list of current version docs. Perhaps something like:
"The user manual for previous versions of GIMP can be found here "
I can add this shortly.
This one is a little different. The "docs.gimp.org" sub-domain is separate from the main www.gimp.org domain, and I haven't had a chance to really familiarize myself with it enough. I'm certainly happy to get something set up for CI/publish of the current docs (but I am also a bit ignorant of how the docs are managed overall...).
I'll ask about getting something setup.
2018-09-12 23:15:03 UTC (over 6 years ago)
On Wed, Sep 12, 2018 at 9:48 AM Pat David via gimp-docs-list < gimp-docs-list@gnome.org> wrote:
Regarding this point specifically. Jenkins is capable of publishing HTML reports of the latest documentation. I would just have to know how the current documentation is generated (shell script maybe?), and which branch is the latest "devel". From there, we can orchestrate Jenkins pipelines that trigger on every commit to master to generate the latest development documentation and host it.
Jenkins can host the devel documentation. The GIMP docs page would simply need to link to the devel docs hosted at Jenkins.
Please create an issue at https://gitlab.gnome.org/World/gimp-ci/jenkins-dsl/issues and answer the following questions:
* Where is the source code repository for the documentation in question? (link to repo)
* How does HTML get generated from the repository? (what are the commands; what dependencies are required)
* Where do I find the documentation after it is generated? (the path in the build tree of the final HTML result)
With that information I can develop a pipeline for you to create these development docs.
2018-09-12 23:18:17 UTC (over 6 years ago)
Awesome, thank you Sam!
This might be something that would be good for me to learn and help with administering. I'm not sure how the docs currently get built, but I'll check into it more and hopefully get an answer to you (assuming someone smarter than I doesn't do it first).
pat
2018-09-12 23:20:23 UTC (over 6 years ago)
Sounds good, thanks! I tried to document everything well in the README and documentation for how to contribute. I'd be curious how well you do trying to contribute using that documentation. It would be a chance to improve the GIMP CI contributor docs for people who are not me :D
pat
* How does HTML get generated from the repository? (what are the commands; what dependencies are required) * Where do I find the documentation after it is generated? (the path in the build tree of the final HTML result)
