GIMP 2.10.x AppImage packages
GIMP 2.10.x AppImage packages Carmelo DrRaw via gimp-developer-list 10 Sep 09:59
  GIMP 2.10.x AppImage packages Ell via gimp-developer-list 10 Sep 16:28
   GIMP 2.10.x AppImage packages Carmelo DrRaw via gimp-developer-list 10 Sep 17:02
    GIMP 2.10.x AppImage packages Jehan Pagès via gimp-developer-list 16 Sep 19:55
     GIMP 2.10.x AppImage packages Carmelo DrRaw via gimp-developer-list 17 Sep 06:54
      GIMP 2.10.x AppImage packages Jehan Pagès via gimp-developer-list 17 Sep 07:14
2018-09-10 09:59:26 UTC (over 6 years ago)
Dear all,
recently I have done additional work on the GIMP AppImage packages, trying to improve the compatibility with various linux distributions and improving the building/packaging scripts.
In a nutshell: * I have moved the build environment to CentOS 7, which is based on glibc 2.17 * the whole appimage creation process now runs through a single bash script that can be executed inside a docker container. This means that the automated integration, now based on Travis CI, can be easily moved to any other system that supports Docker * the appimage packages are now built in two flavours: one “bare” package that only provides GIMP, and a “full-featured” package that also contains few popular and useful plug-ins (including G’MIC-Qt)
The 2.10.7 packages are available for download from here: https://github.com/aferrero2707/gimp-appimage/releases/tag/continuous
Running the AppImages is very simple: * download the package
* make it executable via
chmod u+x
* run the package as any other Linux executable
A note to the developers: the current 2.10.x branch requires a quite recent version of Glib, but only due to the use of a single function in app/gui/splash.c, and only for diagnostics purposes. To circumvent the problem and be able to use the older Glib version available on CentOS 7, I am applying the following patch: https://github.com/aferrero2707/gimp-appimage/blob/master/gimp-glib-splash.patch Is that OK?
As mentioned above, the automated build procedure is currently based on GitHub/TravisCI. However, I am ready to move the scripts to some other CI system if you prefer…
Cheers, Andrea
2018-09-10 16:28:46 UTC (over 6 years ago)
On Mon, 10 Sep 2018 11:59:26 +0200 Carmelo DrRaw via gimp-developer-list wrote:
Dear all,
chmod u+x
Thanks for doing all this. Having the latest-and-greatest code easily available as an AppImage is really awesome :)
Is that OK?
This has already been fixed in the gimp-2-10 branch (master requires a newer GLib version). See commit
499a8962b326823bdf12936960798f802c79f283.
-- Ell
2018-09-10 17:02:44 UTC (over 6 years ago)
Hi!
Is that OK?
Excellent! The new Glib requirement is one of the reasons preventing me to provide an AppImage for the master branch… I need to go through the compilation of Glib from sources, and see if there are no showstoppers on CentOS 7.
Ell
2018-09-16 19:55:33 UTC (over 6 years ago)
Hi!
On Mon, Sep 10, 2018 at 7:03 PM Carmelo DrRaw via gimp-developer-list < gimp-developer-list@gnome.org> wrote:
Hi!
Is that OK?
Also at some point, we should resume discussing making your package upstream. It's hard to make time to discuss this, but this is probably needed. Moreover lately the maintainer of the Snap package approached us to make it upstream as well. So I thought this is the opportunity to discuss about AppImage as well.
Jehan
Ell
https://mail.gnome.org/mailman/listinfo/gimp-developer-list List archives: https://mail.gnome.org/archives/gimp-developer-list
ZeMarmot open animation film
http://film.zemarmot.net
Liberapay: https://liberapay.com/ZeMarmot/
2018-09-17 06:54:48 UTC (over 6 years ago)
Hi Jehan,
On 16 Sep 2018, at 21:55, Jehan Pagès wrote:
Hi!
Would it be ok to continue the discussion in the corresponding GitHub issue? https://github.com/aferrero2707/gimp-appimage/issues/9
Andrea
Jehan
Ell
-- ZeMarmot open animation film
Liberapay: https://liberapay.com/ZeMarmot/ Patreon: https://patreon.com/zemarmot Tipeee: https://www.tipeee.com/zemarmot
2018-09-17 07:14:26 UTC (over 6 years ago)
On Mon, Sep 17, 2018 at 8:54 AM Carmelo DrRaw wrote:
Hi Jehan,
Hi!
Of course. I wrote a comment there actually immediately after my previous email. ;-)
Jehan
Andrea
Jehan
Ell
