Terminal warnings when starting GIMP-2.10/2.99 - mypaint-related?
Terminal warnings when starting GIMP-2.10/2.99 - mypaint-related? Elle Stone 25 Aug 12:53
  Terminal warnings when starting GIMP-2.10/2.99 - mypaint-related? Elle Stone 25 Aug 13:47
Elle Stone
2018-08-25 12:53:11 UTC (over 6 years ago)
Recently when I start GIMP compiled from git, I get a whole bunch of terminal warnings that look to be mypaint-related.
Is anyone else seeing these? Is there something I should update/change/etc?
Here's the code I use to compile libmypaint and the brushes:
cd $SRC_DIR/libmypaint make uninstall & make clean
git clean -xdf
git pull
git checkout v1.3.0
CFLAGS="-march=native -O3 -ffast-math -ftree-vectorize -pipe" CXXFLAGS="${CFLAGS}" ./autogen.sh --prefix=$PREFIX ./configure --prefix=$PREFIX
# Unless something has changed recently, # for libmypaint you do need to run ./autogen.sh and then ./configure make -j4 && make -j4 install
cd $SRC_DIR/mypaint-brushes make uninstall && make clean
git clean -xdf
git pull
git checkout v1.3.0
# You do need to run ./autogen.sh and then ./configure make -j4 && make -j4 install
Here's the terminal warnings when I run GIMP:
Warning: Unknown setting_id: -1 for setting: gridmap_scale Warning: Unknown setting_id: -1 for setting: gridmap_scale_x Warning: Unknown setting_id: -1 for setting: gridmap_scale_y Warning: Unknown setting_id: -1 for setting: offset_angle Warning: Unknown setting_id: -1 for setting: offset_angle_2 Warning: Unknown setting_id: -1 for setting: offset_angle_2_asc Warning: Unknown setting_id: -1 for setting: offset_angle_2_view Warning: Unknown setting_id: -1 for setting: offset_angle_adj Warning: Unknown setting_id: -1 for setting: offset_angle_asc Warning: Unknown setting_id: -1 for setting: offset_angle_view Warning: Unknown setting_id: -1 for setting: offset_multiplier Warning: Unknown setting_id: -1 for setting: offset_x Warning: Unknown setting_id: -1 for setting: offset_y Warning: Unknown setting_id: -1 for setting: posterize Warning: Unknown setting_id: -1 for setting: posterize_num Warning: Unknown setting_id: -1 for setting: smudge_bucket Warning: Unknown setting_id: -1 for setting: smudge_darken Warning: Unknown setting_id: -1 for setting: smudge_desaturation Warning: Unknown setting_id: -1 for setting: smudge_gamma Warning: Unknown setting_id: -1 for setting: smudge_length_log Warning: Unknown setting_id: -1 for setting: smudge_normal_sub Warning: Unknown setting_id: -1 for setting: smudge_spectral Warning: Unknown setting_id: -1 for setting: smudge_transparency Warning: Unknown setting_id: -1 for setting: gridmap_scale Warning: Unknown setting_id: -1 for setting: gridmap_scale_x Warning: Unknown setting_id: -1 for setting: gridmap_scale_y Warning: Unknown setting_id: -1 for setting: offset_angle Warning: Unknown setting_id: -1 for setting: offset_angle_2 Warning: Unknown setting_id: -1 for setting: offset_angle_2_asc Warning: Unknown setting_id: -1 for setting: offset_angle_2_view Warning: Unknown setting_id: -1 for setting: offset_angle_adj Warning: Unknown setting_id: -1 for setting: offset_angle_asc Warning: Unknown setting_id: -1 for setting: offset_angle_view Warning: Unknown setting_id: -1 for setting: offset_multiplier Warning: Unknown setting_id: -1 for setting: offset_x Warning: Unknown setting_id: -1 for setting: offset_y Warning: Unknown setting_id: -1 for setting: posterize Warning: Unknown setting_id: -1 for setting: posterize_num Warning: Unknown setting_id: -1 for setting: smudge_bucket Warning: Unknown setting_id: -1 for setting: smudge_darken Warning: Unknown setting_id: -1 for setting: smudge_desaturation Warning: Unknown setting_id: -1 for setting: smudge_gamma Warning: Unknown setting_id: -1 for setting: smudge_length_log Warning: Unknown setting_id: -1 for setting: smudge_normal_sub Warning: Unknown setting_id: -1 for setting: smudge_spectral Warning: Unknown setting_id: -1 for setting: smudge_transparency Warning: Unknown setting_id: -1 for setting: gridmap_scale Warning: Unknown setting_id: -1 for setting: gridmap_scale_x Warning: Unknown setting_id: -1 for setting: gridmap_scale_y Warning: Unknown setting_id: -1 for setting: offset_angle Warning: Unknown setting_id: -1 for setting: offset_angle_2 Warning: Unknown setting_id: -1 for setting: offset_angle_2_asc Warning: Unknown setting_id: -1 for setting: offset_angle_2_view Warning: Unknown setting_id: -1 for setting: offset_angle_adj Warning: Unknown setting_id: -1 for setting: offset_angle_asc Warning: Unknown setting_id: -1 for setting: offset_angle_view Warning: Unknown setting_id: -1 for setting: offset_multiplier Warning: Unknown setting_id: -1 for setting: offset_x Warning: Unknown setting_id: -1 for setting: offset_y Warning: Unknown setting_id: -1 for setting: posterize Warning: Unknown setting_id: -1 for setting: posterize_num Warning: Unknown setting_id: -1 for setting: smudge_bucket Warning: Unknown setting_id: -1 for setting: smudge_darken Warning: Unknown setting_id: -1 for setting: smudge_desaturation Warning: Unknown setting_id: -1 for setting: smudge_gamma Warning: Unknown setting_id: -1 for setting: smudge_length_log Warning: Unknown setting_id: -1 for setting: smudge_normal_sub Warning: Unknown setting_id: -1 for setting: smudge_spectral Warning: Unknown setting_id: -1 for setting: smudge_transparency Warning: Unknown setting_id: -1 for setting: gridmap_scale Warning: Unknown setting_id: -1 for setting: gridmap_scale_x Warning: Unknown setting_id: -1 for setting: gridmap_scale_y Warning: Unknown setting_id: -1 for setting: offset_angle Warning: Unknown setting_id: -1 for setting: offset_angle_2 Warning: Unknown setting_id: -1 for setting: offset_angle_2_asc Warning: Unknown setting_id: -1 for setting: offset_angle_2_view Warning: Unknown setting_id: -1 for setting: offset_angle_adj Warning: Unknown setting_id: -1 for setting: offset_angle_asc Warning: Unknown setting_id: -1 for setting: offset_angle_view Warning: Unknown setting_id: -1 for setting: offset_multiplier Warning: Unknown setting_id: -1 for setting: offset_x Warning: Unknown setting_id: -1 for setting: offset_y Warning: Unknown setting_id: -1 for setting: posterize Warning: Unknown setting_id: -1 for setting: posterize_num Warning: Unknown setting_id: -1 for setting: smudge_bucket Warning: Unknown setting_id: -1 for setting: smudge_darken Warning: Unknown setting_id: -1 for setting: smudge_desaturation Warning: Unknown setting_id: -1 for setting: smudge_gamma Warning: Unknown setting_id: -1 for setting: smudge_length_log Warning: Unknown setting_id: -1 for setting: smudge_normal_sub Warning: Unknown setting_id: -1 for setting: smudge_spectral Warning: Unknown setting_id: -1 for setting: smudge_transparency Warning: Unknown setting_id: -1 for setting: gridmap_scale Warning: Unknown setting_id: -1 for setting: gridmap_scale_x Warning: Unknown setting_id: -1 for setting: gridmap_scale_y Warning: Unknown setting_id: -1 for setting: offset_angle Warning: Unknown setting_id: -1 for setting: offset_angle_2 Warning: Unknown setting_id: -1 for setting: offset_angle_2_asc Warning: Unknown setting_id: -1 for setting: offset_angle_2_view Warning: Unknown setting_id: -1 for setting: offset_angle_adj Warning: Unknown setting_id: -1 for setting: offset_angle_asc Warning: Unknown setting_id: -1 for setting: offset_angle_view Warning: Unknown setting_id: -1 for setting: offset_multiplier Warning: Unknown setting_id: -1 for setting: offset_x Warning: Unknown setting_id: -1 for setting: offset_y Warning: Unknown setting_id: -1 for setting: posterize Warning: Unknown setting_id: -1 for setting: posterize_num Warning: Unknown setting_id: -1 for setting: smudge_bucket Warning: Unknown setting_id: -1 for setting: smudge_darken Warning: Unknown setting_id: -1 for setting: smudge_desaturation Warning: Unknown setting_id: -1 for setting: smudge_gamma Warning: Unknown setting_id: -1 for setting: smudge_length_log Warning: Unknown setting_id: -1 for setting: smudge_normal_sub Warning: Unknown setting_id: -1 for setting: smudge_spectral Warning: Unknown setting_id: -1 for setting: smudge_transparency Warning: Unknown setting_id: -1 for setting: gridmap_scale Warning: Unknown setting_id: -1 for setting: gridmap_scale_x Warning: Unknown setting_id: -1 for setting: gridmap_scale_y Warning: Unknown setting_id: -1 for setting: offset_angle Warning: Unknown setting_id: -1 for setting: offset_angle_2 Warning: Unknown setting_id: -1 for setting: offset_angle_2_asc Warning: Unknown setting_id: -1 for setting: offset_angle_2_view Warning: Unknown setting_id: -1 for setting: offset_angle_adj Warning: Unknown setting_id: -1 for setting: offset_angle_asc Warning: Unknown setting_id: -1 for setting: offset_angle_view Warning: Unknown setting_id: -1 for setting: offset_multiplier Warning: Unknown setting_id: -1 for setting: offset_x Warning: Unknown setting_id: -1 for setting: offset_y Warning: Unknown setting_id: -1 for setting: posterize Warning: Unknown setting_id: -1 for setting: posterize_num Warning: Unknown setting_id: -1 for setting: smudge_bucket Warning: Unknown setting_id: -1 for setting: smudge_darken Warning: Unknown setting_id: -1 for setting: smudge_desaturation Warning: Unknown setting_id: -1 for setting: smudge_gamma Warning: Unknown setting_id: -1 for setting: smudge_length_log Warning: Unknown setting_id: -1 for setting: smudge_normal_sub Warning: Unknown setting_id: -1 for setting: smudge_spectral Warning: Unknown setting_id: -1 for setting: smudge_transparency
Best, Elle
Elle Stone
2018-08-25 13:47:42 UTC (over 6 years ago)
OK, I just got a private email suggesting that GIMP was looking for mypaint brushes in $HOME/.mypaint and that perhaps I had a modified set of mypaint brushes from a "not default" installation of mypaint. Which was exactly the case.
So I removed $HOME/.mypaint from the list of folders GIMP could look in for mypaint brushes, and that got rid of the terminal warnings.
I don't know if the person who sent the private email really did mean only to respond to me. But in any case thanks! that solved the problem.
Best, Elle
git clean -xdf
git pull
git checkout v1.3.0
git clean -xdf
git pull
git checkout v1.3.0
Best, Elle
List address:    gimp-developer-list@gnome.org List membership:
https://mail.gnome.org/mailman/listinfo/gimp-developer-list List archives:   https://mail.gnome.org/archives/gimp-developer-list
https://ninedegreesbelow.com
Color management and free/libre photography
