How can run two GIMP instances ?
How can run two GIMP instances ? sebul via gimp-developer-list 22 Jun 19:41
  How can run two GIMP instances ? Partha Bagchi via gimp-developer-list 22 Jun 20:39
   How can run two GIMP instances ? sebul via gimp-developer-list 22 Jun 21:02
   How can run two GIMP instances ? sebul via gimp-developer-list 23 Jun 06:53
2018-06-22 19:41:40 UTC (almost 7 years ago)
Hello, I'm a Korean GIMP user.
I read https://www.gimp.org/downloads/ and I installed gimp by flatpak.
I want run two GIMP instances, so one has English Menu and the other Korean.
The following link does not help me. https://docs.gimp.org/2.10/en/gimp-fire-up.html#gimp-concepts-running-command-line
In command line $ gimp
not work.
Help me please.
2018-06-22 20:39:20 UTC (almost 7 years ago)
On Fri, Jun 22, 2018 at 3:42 PM sebul via gimp-developer-list < gimp-developer-list@gnome.org> wrote:
not work.
Help me please.
gimp -n
2018-06-22 21:02:54 UTC (almost 7 years ago)
Did you install gimp by flatpak ?
I know gimp -n but after install by flatpak, even
gimp
command does not work.
2018년 6월 23일 (토) 오전 5:39, Partha Bagchi 님이 작성:
not work.
Help me please.
gimp -n
세벌식 http://sebul.sarang.net
2018-06-23 06:53:14 UTC (almost 7 years ago)
Thank you for your hint.
I found a solution.
In a terminal flatpak run org.gimp.GIMP -n &
And then Edit - Preferences - Interface - Language and select 한국어[ko]
Ok
And in a terminal
Then gimp with Korean language appear.
not work.
Help me please.
gimp -n
