GIMP 2.99 window size
GIMP 2.99 window size Draekko Software 31 May 11:55
Draekko Software
2018-05-31 11:55:45 UTC (almost 7 years ago)
| There was a minimum size until yesterday which I fixed,
| now it should require the size needed by docks.
| Mitch
Good to know, will update my local repo, did fix it through my new dark theme for it.
The problem is with some themes are setting the icon size for the toolbar to something too big which causes it to expand and because of the "coded rules" it can't shrink to fit the display.
Will pull the new code now :)
Ben
