The gimp-help-2 repository has moved to Gitlab.
9 of 9 messages available
The gimp-help-2 repository has moved to Gitlab. ΔΗΜΗΤΡΗΣ Σ 28 May 06:19
  The gimp-help-2 repository has moved to Gitlab. Marco Ciampa 28 May 13:45
   The gimp-help-2 repository has moved to Gitlab. ΔΗΜΗΤΡΗΣ Σ 28 May 16:16
    The gimp-help-2 repository has moved to Gitlab. Alexandre Prokoudine 28 May 16:18
     The gimp-help-2 repository has moved to Gitlab. ΔΗΜΗΤΡΗΣ Σ 28 May 16:26
      The gimp-help-2 repository has moved to Gitlab. Marco Ciampa 28 May 21:02
       The gimp-help-2 repository has moved to Gitlab. ΔΗΜΗΤΡΗΣ Σ 29 May 06:37
        The gimp-help-2 repository has moved to Gitlab. Michael Schumacher 29 May 06:42
         The gimp-help-2 repository has moved to Gitlab. ΔΗΜΗΤΡΗΣ Σ 29 May 06:52
ΔΗΜΗΤΡΗΣ Σ
2018-05-28 06:19:21 UTC (almost 7 years ago)
while I was trying to send some translations, I received the message:
remote: --- remote: The gimp-help-2 repository has moved to Gitlab. Please update remote: your Git remote to:
remote:
remote: git@gitlab.gnome.org:GNOME/gimp-help-2.git remote:
remote: ---
To ssh://dimspingos@git.gnome.org/git/gimp-help-2 ! [remote rejected] master -> master (pre-receive hook declined) error: failed to push some refs to 'ssh:// dimspingos@git.gnome.org/git/gimp-help-2'
what exactly should I do?
Marco Ciampa
2018-05-28 13:45:05 UTC (almost 7 years ago)
remote:
remote: ---
He he welcome to the club! See this
https://wiki.gnome.org/AccountsTeam/RetrieveYourGNOMEAccountPassword
and the gitlab thread above...
if in doubt, ask here...
Marco Ciampa
I know a joke about UDP, but you might not get it.
GNU/Linux User #78271 FSFE fellow #364
ΔΗΜΗΤΡΗΣ Σ
2018-05-28 16:16:58 UTC (almost 7 years ago)
I've received no message either in inbox, or in spams. With ssh -l $userid account.gnome.org, it appears
usage: ssh [-(here there is a string)] [-b bind_address] [-c cipher_spec] [-D [bind_address:]port] [-E log_file] [-e escape_char] [-F configfile] [-I pkcs11] [-i identity_file] [-L address] [-l login_name] [-m mac_spec] [-O ctl_cmd] [-o option] [-p port] [-Q query_option] [-R address] [-S ctl_path] [-W host:port] [-w local_tun[:remote_tun]] [user@]hostname [command]
I've seen no light.
2018-05-28 16:45 GMT+03:00 Marco Ciampa :
remote:
remote: ---
Marco Ciampa
_______________________________________________ gimp-docs-list mailing list
gimp-docs-list@gnome.org
2018-05-28 16:18:44 UTC (almost 7 years ago)
You are supposed to replace $userid with your actual username in GNOME.
Alex
ΔΗΜΗΤΡΗΣ Σ
2018-05-28 16:26:55 UTC (almost 7 years ago)
I used it, too.
The same result.
2018-05-28 19:18 GMT+03:00 Alexandre Prokoudine < alexandre.prokoudine@gmail.com>:
Alex _______________________________________________ gimp-docs-list mailing list
Marco Ciampa
2018-05-28 21:02:33 UTC (almost 7 years ago)
On Mon, May 28, 2018 at 07:26:55PM +0300, ΔΗΜΗΤΡΗΣ Σ wrote:
I used it, too.
The same result.
Please post your old .git/config here... (there should be not secrets there just your username...)
Marco Ciampa
ΔΗΜΗΤΡΗΣ Σ
2018-05-29 06:37:46 UTC (almost 7 years ago)
[color]
ui = auto
[alias]
up = pull --rebase
[push]
default = tracking
[user]
email = dmtrs32@gmail.com
name = Dimitris Spingos (Δημήτρης Σπίγγος)
With user name:dmtrs32 ssh -l $dmtrs32 account.gnome.org
gives:
usage: ssh [-(a string here)] [-b bind_address] [-c cipher_spec] [-D [bind_address:]port] [-E log_file] [-e escape_char] [-F configfile] [-I pkcs11] [-i identity_file] [-L address] [-l login_name] [-m mac_spec] [-O ctl_cmd] [-o option] [-p port] [-Q query_option] [-R address] [-S ctl_path] [-W host:port] [-w local_tun[:remote_tun]] [user@]hostname [command]
2018-05-29 0:02 GMT+03:00 Marco Ciampa :
I used it, too.
The same result.
Marco Ciampa
2018-05-29 06:42:14 UTC (almost 7 years ago)
On May 29, 2018 8:37:46 AM GMT+02:00, "ΔΗΜΗΤΡΗΣ Σ" wrote:
[color]
ui = auto
[alias]
up = pull --rebase
[push]
default = tracking
[user]
Drop the $
$foo et al is a common convention for placeholders and supposed to be replaced by the actual value.
ΔΗΜΗΤΡΗΣ Σ
2018-05-29 06:52:20 UTC (almost 7 years ago)
With:
ssh -l dmtrs32 account.gnome.org
gives:
Permission denied (publickey,gssapi-keyex,gssapi-with-mic).
2018-05-29 9:42 GMT+03:00 Michael Schumacher :
[color]
ui = auto
[alias]
up = pull --rebase
[push]
default = tracking
[user]
Drop the $
-- Regards,
GPG: 96A8 B38A 728A 577D 724D 60E5 F855 53EC B36D 4CDD _______________________________________________ gimp-docs-list mailing list
