gitlab(2)
gitlab(2) Julien Hardelin 26 May 13:27
  gitlab(2) Pat David 26 May 19:00
Julien Hardelin
2018-05-26 13:27:18 UTC (almost 7 years ago)
gitlab(2)
/~/gimp-help-2> git push//
//Enter passphrase for key '/home/*****/.ssh/id_rsa': // //Counting objects: 9, done.//
//Delta compression using up to 2 threads.// //Compressing objects: 100% (5/5), done.// //Writing objects: 100% (5/5), 916 bytes, done.// //Total 5 (delta 4), reused 0 (delta 0)// //remote: ---//
//remote: The gimp-help-2 repository has moved to Gitlab. Please update// //remote: your Git remote to://
//remote: //
//remote:     git@gitlab.gnome.org:GNOME/gimp-help-2.git// //remote: //
//remote: ---//
//To ssh://*****@git.gnome.org/git/gimp-help-2// // ! [remote rejected] master -> master (pre-receive hook declined)// //error: failed to push some refs to 'ssh://*****@git.gnome.org/git/gimp-help-2/'
How to update my Git remote to git@gitlab.gnome.org/git/gimp-help-2 ?
Julien
Pat David
2018-05-26 19:00:15 UTC (almost 7 years ago)
gitlab(2)
I haven't tested this yet, but the remote should show up in your gimp-help-2/.git/config file. You might be able to change the section
``` [remote "origin"]
url = ...{changeme}...
Not sure if this will work, though, so test carefully. :)
On Sat, May 26, 2018 at 8:27 AM Julien Hardelin wrote:
*~/gimp-help-2> git push*
*Enter passphrase for key '/home/*****/.ssh/id_rsa': * *Counting objects: 9, done.*
*Delta compression using up to 2 threads.* *Compressing objects: 100% (5/5), done.* *Writing objects: 100% (5/5), 916 bytes, done.* *Total 5 (delta 4), reused 0 (delta 0)* *remote: ---*
*remote: The gimp-help-2 repository has moved to Gitlab. Please update* *remote: your Git remote to:*
*remote: *
*remote: git@gitlab.gnome.org:GNOME/gimp-help-2.git *
*remote: *
*remote: ---*
*To ssh://*****@git.gnome.org/git/gimp-help-2* * ! [remote rejected] master -> master (pre-receive hook declined)* *error: failed to push some refs to
'ssh://*****@git.gnome.org/git/gimp-help-2*'
Julien
_______________________________________________ gimp-docs-list mailing list
gimp-docs-list@gnome.org
https://patdavid.net
GPG: 66D1 7CA6 8088 4874 946D  18BD 67C7 6219 89E9 57AC
