Black point compensation algorithm
Black point compensation algorithm fri.orths 14 May 07:03
  Black point compensation algorithm Tobias Ellinghaus 14 May 09:03
fri.orths
2018-05-14 07:03:14 UTC (almost 7 years ago)
Dear Developer-List,
as part of my research on a seminar paper with the subject „black point compensation“ I also came across the graphics program GIMP. In some sources it was mentioned that in Gimp you can definitely select or deselect black point compensation. I am aware of how the BPC works in general. What I need is information about the algorithm behind it. Is it perhaps from Adobe (Photoshop), or from the ISO 18619: 2015? Unfortunately, I could not find anything about it on your pages. Can you help me with this?
Many thanks in advance for your reply.
With kind regards,
Frieda Orths
Tobias Ellinghaus
2018-05-14 09:03:56 UTC (almost 7 years ago)
Am Montag, 14. Mai 2018, 09:03:14 CEST schrieb fri.orths:
GIMP uses the bpc provided by lcms2[0]. No idea what algorithm that uses internally, it might be the same as Adobe uses [1].
With kind regards,
Frieda Orths
Tobias
[0] http://www.littlecms.com/ [1] https://sourceforge.net/p/lcms/mailman/message/8134197/
