GNU++11 not allowed with Objective-C code
10 of 10 messages available
GNU++11 not allowed with Objective-C code Partha Bagchi 07 Apr 16:41
  GNU++11 not allowed with Objective-C code Ell via gimp-developer-list 07 Apr 17:24
   GNU++11 not allowed with Objective-C code Partha Bagchi 07 Apr 19:43
    GNU++11 not allowed with Objective-C code Partha Bagchi 07 Apr 20:56
    GNU++11 not allowed with Objective-C code Ell via gimp-developer-list 07 Apr 21:03
     GNU++11 not allowed with Objective-C code Partha Bagchi 07 Apr 21:17
      GNU++11 not allowed with Objective-C code Partha Bagchi 07 Apr 21:35
       GNU++11 not allowed with Objective-C code Ell via gimp-developer-list 07 Apr 22:00
        GNU++11 not allowed with Objective-C code Ell via gimp-developer-list 08 Apr 11:07
         GNU++11 not allowed with Objective-C code Partha Bagchi 08 Apr 11:28
Partha Bagchi
2018-04-07 16:41:10 UTC (about 7 years ago)
Ell my friend, it's me again. :)
We can't use gnu++11 with objective-c code.
CXX gimp-parallel.o
error: invalid argument '-std=gnu++11' not allowed with 'Objective-C'
make[3]: *** [gimp-parallel.o] Error 1
So, how do we fix this? Also, shouldn't we be using c++11 or c++14 to be generic?
Thanks,
Patha
2018-04-07 17:24:57 UTC (about 7 years ago)
CXX gimp-parallel.o
The specific compiler flag is chosen by some configure magic, so it should generally be ok. A little googling shows that people are getting the same error with -std=c++11 too.
I'm not sure why clang tries to compile this as objective-c, though. Can you post the output of $ make V=1 ?
-- Ell
Partha Bagchi
2018-04-07 19:43:30 UTC (about 7 years ago)
On Sat, Apr 7, 2018 at 1:24 PM, Ell via gimp-developer-list < gimp-developer-list@gnome.org> wrote:
CXX gimp-parallel.o
-- Ell
My apologies. I should have framed that as 2 different issues. One about
the compilation and the other that we should probably be using C++14 (or 11) instead of gnu++11.
In any case, the verbose mode may not be particularly helpful:
g++ -DHAVE_CONFIG_H -I. -I../.. -DGIMPDIR=\""GIMP"\" -DGIMP_APP_VERSION=\"2.10\" -DGIMP_USER_VERSION=\"2.10\" -DG_LOG_DOMAIN=\"Gimp-Core\" -I../.. -I../.. -I../../app -I../../app -I/Users/partha/local10.9/include/cairo -I/Users/partha/local10.9/include/pixman-1 -I/Users/partha/local10.9/include
-I/Users/partha/local10.9/include/freetype2 -I/Users/partha/local10.9/include
-I/Users/partha/local10.9/include/libpng16 -I/Users/partha/local10.9/include/harfbuzz -I/Users/partha/local10.9/include/glib-2.0 -I/Users/partha/local10.9/lib/glib-2.0/include -I/Users/partha/local10.9/include
-I/Users/partha/local10.9/include/freetype2 -I/Users/partha/local10.9/include/harfbuzz -I/Users/partha/local10.9/include/glib-2.0 -I/Users/partha/local10.9/lib/glib-2.0/include -I/Users/partha/local10.9/include/libpng16 -I/Users/partha/local10.9/include -D_REENTRANT -I/Users/partha/local10.9/include/json-glib-1.0 -I/Users/partha/local10.9/include/gio-unix-2.0/ -I/Users/partha/local10.9/include/glib-2.0 -I/Users/partha/local10.9/lib/glib-2.0/include -I/Users/partha/local10.9/mcgimp-std/Contents/Resources/include/gegl-0.3 -I/Users/partha/local10.9/mcgimp-std/Contents/Resources/include/babl-0.1 -D_REENTRANT -I/Users/partha/local10.9/include/gdk-pixbuf-2.0 -I/Users/partha/local10.9/include/libpng16 -I/Users/partha/local10.9/include
-I/Users/partha/local10.9/include/glib-2.0 -I/Users/partha/local10.9/lib/glib-2.0/include -I/Users/partha/local10.9/include/libmypaint -I/Users/partha/local10.9/include/json-c -I/Users/partha/local10.9/include/glib-2.0 -I/Users/partha/local10.9/lib/glib-2.0/include -I/Users/partha/local10.9/include
-I/Users/partha/local10.9/include/glib-2.0 -I/Users/partha/local10.9/lib/glib-2.0/include -I/Users/partha/local10.9/mcgimp-std/Contents/Resources/include "-xobjective-c" -I/Users/partha/local10.9/include -DGIMP_DISABLE_DEPRECATED -DBABL_DISABLE_DEPRECATED -DGSEAL_ENABLE -DGDK_DISABLE_DEPRECATED -DGTK_DISABLE_DEPRECATED -DGDK_MULTIHEAD_SAFE -DGTK_MULTIHEAD_SAFE -std=c++14 -O3 -ffast-math -ftree-vectorize -mmacosx-version-min=10.9 -MT gimp-parallel.o -MD -MP -MF .deps/gimp-parallel.Tpo -c -o gimp-parallel.o gimp-parallel.cc
error: invalid argument '-std=c++14' not allowed with 'Objective-C' make: *** [gimp-parallel.o] Error 1
In there you can see "-xobjective-c" is being used to compile gimp-parallel.cc. Also, you're seeing -std=c++14 because I have CXXFLAGS defined that way.
Thanks,
Partha
Partha Bagchi
2018-04-07 20:56:58 UTC (about 7 years ago)
CXX gimp-parallel.o
-- Ell
g++ -DHAVE_CONFIG_H -I. -I../.. -DGIMPDIR=\""GIMP"\" -DGIMP_APP_VERSION=\"2.10\" -DGIMP_USER_VERSION=\"2.10\" -DG_LOG_DOMAIN=\"Gimp-Core\" -I../.. -I../.. -I../../app -I../../app -I/Users/partha/local10.9/include/cairo -I/Users/partha/local10.9/include/pixman-1 -I/Users/partha/local10.9/include -I/Users/partha/local10.9/include/freetype2 -I/Users/partha/local10.9/include -I/Users/partha/local10.9/include/libpng16 -I/Users/partha/local10.9/include/harfbuzz -I/Users/partha/local10.9/include/glib-2.0 -I/Users/partha/local10.9/lib/glib-2.0/include -I/Users/partha/local10.9/include -I/Users/partha/local10.9/include/freetype2 -I/Users/partha/local10.9/include/harfbuzz -I/Users/partha/local10.9/include/glib-2.0 -I/Users/partha/local10.9/lib/glib-2.0/include -I/Users/partha/local10.9/include/libpng16 -I/Users/partha/local10.9/include -D_REENTRANT -I/Users/partha/local10.9/include/json-glib-1.0 -I/Users/partha/local10.9/include/gio-unix-2.0/ -I/Users/partha/local10.9/include/glib-2.0 -I/Users/partha/local10.9/lib/glib-2.0/include -I/Users/partha/local10.9/ mcgimp-std/Contents/Resources/include/gegl-0.3 -I/Users/partha/local10.9/ mcgimp-std/Contents/Resources/include/babl-0.1 -D_REENTRANT -I/Users/partha/local10.9/include/gdk-pixbuf-2.0 -I/Users/partha/local10.9/include/libpng16 -I/Users/partha/local10.9/include -I/Users/partha/local10.9/include/glib-2.0 -I/Users/partha/local10.9/lib/glib-2.0/include -I/Users/partha/local10.9/include/libmypaint -I/Users/partha/local10.9/include/json-c -I/Users/partha/local10.9/include/glib-2.0 -I/Users/partha/local10.9/lib/glib-2.0/include -I/Users/partha/local10.9/include -I/Users/partha/local10.9/include/glib-2.0 -I/Users/partha/local10.9/lib/glib-2.0/include -I/Users/partha/local10.9/ mcgimp-std/Contents/Resources/include "-xobjective-c" -I/Users/partha/local10.9/include -DGIMP_DISABLE_DEPRECATED -DBABL_DISABLE_DEPRECATED -DGSEAL_ENABLE -DGDK_DISABLE_DEPRECATED -DGTK_DISABLE_DEPRECATED -DGDK_MULTIHEAD_SAFE -DGTK_MULTIHEAD_SAFE -std=c++14 -O3 -ffast-math -ftree-vectorize -mmacosx-version-min=10.9 -MT gimp-parallel.o -MD -MP -MF .deps/gimp-parallel.Tpo -c -o gimp-parallel.o gimp-parallel.cc
Thanks,
Partha
As a further test, I tried this:
c++ -std=c++14 -O3 -ffast-math -ftree-vectorize -mmacosx-version-min=10.9 -c gimp-parallel.cc -I. -I../.. `pkg-config --cflags glib-2.0` `pkg-config --cflags gegl-0.3` -I..
It compiles fine. Hope that's helpful.
2018-04-07 21:03:56 UTC (about 7 years ago)
The exact flag we use is not hard coded, it's determined by AX_CXX_COMPILE_STDCXX() during configure. We *could* ask it for a strictly standard-compliant mode, but we're not that concerned about it. We might want to use some GCC extension, based on some other configure test, or whatnot.
Thanks. So, we've been passing "-xobjective-c" unconditionally to all compiled files on Mac. Commit 06950be7f0 should fix that, only passing it when compiling C files.
Ell
Partha Bagchi
2018-04-07 21:17:23 UTC (about 7 years ago)
Ell
I was about to post that!!
Anyway, I did a git pull and something went haywire. I don't know what! I even did make distclean. I am getting realms of text starting with:
Making all in tools
cd .. && /bin/sh
/Users/partha/projects/src/gimp/gitsource/std/gimp/missing automake-1.15 --gnu tools/Makefile
cd .. && /bin/sh ./config.status tools/Makefile depfiles config.status: creating tools/Makefile config.status: executing depfiles commands CCLD gimptool-2.0
gimptool.o:1:1: error: source file is not valid UTF-8
gimptool.o:1:2: error: source file is not valid UTF-8
gimptool.o:1:3: error: source file is not valid UTF-8
gimptool.o:1:4: error: source file is not valid UTF-8
gimptool.o:1:5: error: expected identifier or '('
gimptool.o:1:6: warning: null character ignored [-Wnull-character]
gimptool.o:1:7: warning: null character ignored [-Wnull-character]
Partha Bagchi
2018-04-07 21:35:20 UTC (about 7 years ago)
Ell
Making all in tools
cd .. && /bin/sh /Users/partha/projects/src/gimp/gitsource/std/gimp/missing automake-1.15 --gnu tools/Makefile
gimptool.o:1:1: error: source file is not valid UTF-8 <
U+0000><
U+0004>...
gimptool.o:1:2: error: source file is not valid UTF-8 <
U+0000><
U+0004>...
gimptool.o:1:3: error: source file is not valid UTF-8 <
U+0000><
U+0004>...
gimptool.o:1:4: error: source file is not valid UTF-8 <
U+0000><
U+0004>...
gimptool.o:1:5: error: expected identifier or '(' <
U+0000><
U+0004>...
gimptool.o:1:6: warning: null character ignored [-Wnull-character] <
U+0000><
U+0004>...
gimptool.o:1:7: warning: null character ignored [-Wnull-character] <
U+0000><
U+0004>...
Confirmed. It's something you did!! :) :)
Anyway, reverted back to previous head and c++14 error is back but all the above is gone.
2018-04-07 22:00:57 UTC (about 7 years ago)
Ha, of course it is :) The commit caused -xobjective-c to be passed during linking too, and this apparently causes the object file to be treated as a source file. We'll need to untangle this mess, but not today :)
Ell
2018-04-08 11:07:16 UTC (about 7 years ago)
This should be fixed now, by commit 6ebc3f1b09. Hopefully, for real this time :)
Ell
Partha Bagchi
2018-04-08 11:28:24 UTC (about 7 years ago)
On Sun, Apr 8, 2018 at 7:07 AM, Ell via gimp-developer-list < gimp-developer-list@gnome.org> wrote:
Ell
Ha! We'll see! :)
OK, ok, it's seems fixed now. Have a great Sunday. :)
