autogen.sh not finding automake
autogen.sh not finding automake Kolbjørn Stuestøl 18 Dec 12:33
  autogen.sh not finding automake Alexandre Prokoudine 18 Dec 12:57
   autogen.sh not finding automake Kolbjørn Stuestøl 18 Dec 15:59
Kolbjørn Stuestøl
2017-12-18 12:33:15 UTC (over 7 years ago)
Where is autogen.sh getting it's information about where automake is?
When I am running "./autogen.sh  …" I get an error message from autogen.sh saying that I must have automake 1.10 or newer installed to compile gimp-help-2. It looks like autogen.sh does not recognize the automake file installed. I think I have to manually insert a path to the autogen file, but where and how?
Automake-1.9.6 installed itself in usr/share. I have not tried with an older version of automake.
I am running this using Cygwin in Windows 10, but perhaps the solution is the same as in Linux.
I have tried to update automake from Cygwin and also downloaded the file automake-1.9.6.tar.gz and install it  with "tar -xvzf". Neither of them helped me out.
All works fine on Windows 7 with automake -1.14.
Hoping for help as I am not able to translate GIMP using my main computer. Kolbjørn
Denne e-posten har blitt sjekket for virus av antivirusprogramvare fra Avast https://www.avast.com/antivirus
2017-12-18 12:57:04 UTC (over 7 years ago)
Automake-1.9.6
...is an older version than 1.10.
Which is why...
...because 1.12 is newer than 1.10.
1.9 < 1.10 < 1.11 etc.
The dot is not a decimal denominator.
Alex
Kolbjørn Stuestøl
2017-12-18 15:59:17 UTC (over 7 years ago)
Den 18.12.2017 13:57, skreiv Alexandre Prokoudine:
Automake-1.9.6
Which is why...
Looks  not logic to me :-)
Thank you. I'll change my automake version. I thought it was  a (sort of) decimal number. Just as GIMP 8.6 is a newer version then 8.4.
Kolbjørn
Alex
_______________________________________________ gimp-docs-list mailing list
gimp-docs-list@gnome.org
