Exposure clamping.
Exposure clamping. Mario Sottile - Marionetas Mey 07 Nov 18:46
  Exposure clamping. Øyvind Kolås 15 Nov 00:48
   Exposure clamping. Mario Sottile - Marionetas Mey 16 Nov 12:09
2017-11-07 18:46:03 UTC (over 7 years ago)
Exposure clamping.
Hello there. I made a simple test in Gimp 2.9.6 commit c97c2fe06d.
I created a 32bits floating point, lineal light Gamma, new archive. I select 50% RGB gray color and fill everything. I applied a Exposure of 10 to it.
Now, I took the color picker and click on image. It says:
If 0.21 is the middle gray for lineal middle gray of sRGB...
2^10= 1024 1024*0.21= *215*
... but GIMP says: 21,4.
Why is it clamped at +- 6.7 stops?
What if I want to edit an EXR from Blender?
Thanks in advance.
Marionetas Mey
Mario Sottile - Director
(011) 15.6283.1576
www.mariomey.com.ar
info@mariomey.com.ar
Øyvind Kolås
2017-11-15 00:48:39 UTC (over 7 years ago)
Exposure clamping.
Thank you for spotting this, the exposure operation encoded a maximum gain of 100.0 when avoiding a division by zero, this arbitrary limit has been increased in git master:
commit a1c2b693e92c07c3af8b6a632fe5228422d23f3b Author: Øyvind Kolås
Date: Wed Nov 15 01:39:13 2017 +0100
exposure: adjust clamping to avoid division by 0
The code contained MIN (reciprocal, 0.01) to avoid division by zero, resulting
in a maximum gain of 100.0, this changes it to a maximum gain of 1000000.0, with some non-photographic sources such gains are entirely reasonable.
/pippin - http://pippin.gimp.org/
2017-11-16 12:09:18 UTC (over 7 years ago)
Exposure clamping.
Thanks, man! It will be very usefull for, as you said, non-photographic sources.
