gimp git/master failed to build
gimp git/master failed to build Jean-Luc Coulon (f5ibh) 10 Sep 08:07
2017-09-10 08:07:18 UTC (over 7 years ago)
I've the following error:
/gimp-2.9.8=. -fstack-protector-strong -Wformat -Werror=format-security -Wall -Wdeclaration-after-statement -Wmissing-prototypes -Werror=missing-prototypes -Wmissing-declarations -Winit-self -Wpointer-arith -Wmissing-format-attribute -Wformat-security -Wlogical-op -Wtype-limits -fno-common -fdiagnostics-show-option -Wreturn-type -c gimpcolorspace.c -fPIC -DPIC -o .libs/gimpcolorspace.o /bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I.. -DG_LOG_DOMAIN=\"LibGimpColor\" -DGIMP_COLOR_COMPILATION -I.. -pthread -I/usr/include/gegl-0.3 -I/usr/include/json-glib-1.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/include/babl-0.1 -I/usr/include/cairo -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/libpng16 -pthread -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/libpng16 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/include -Wdate-time -D_FORTIFY_SOURCE=2 -DGIMP_DISABLE_DEPRECATED -DBABL_DISABLE_DEPRECATED -DGSEAL_ENABLE -DGDK_DISABLE_DEPRECATED -DGTK_DISABLE_DEPRECATED -DGDK_MULTIHEAD_SAFE -DGTK_MULTIHEAD_SAFE -g -O2 -fdebug-prefix-map=/usr/local/src/gimp/gimp-2.9.8=. -fstack-protector-strong -Wformat -Werror=format-security -Wall -Wdeclaration-after-statement -Wmissing-prototypes -Werror=missing-prototypes -Wmissing-declarations -Winit-self -Wpointer-arith -Wmissing-format-attribute -Wformat-security -Wlogical-op -Wtype-limits -fno-common -fdiagnostics-show-option -Wreturn-type -c -o gimphsl.lo gimphsl.c
gimpcolorprofile.c: In function ‘gimp_color_profile_get_format’: gimpcolorprofile.c:1482:32: error: ‘BABL_ICC_INTENT_RELATIVE_COLORIMETRIC’ undeclared (first use in this function); did you mean ‘INTENT_RELATIVE_COLORIMETRIC’?
BABL_ICC_INTENT_RELATIVE_COLORIMETRIC, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ INTENT_RELATIVE_COLORIMETRIC gimpcolorprofile.c:1482:32: note: each undeclared identifier is reported only once for each function it appears in gimpcolorprofile.c:1480:11: error: too many arguments to function ‘babl_space_from_icc’
space = babl_space_from_icc ((const gchar *) profile->priv->data, ^~~~~~~~~~~~~~~~~~~
In file included from /usr/include/gegl-0.3/gegl.h:23:0, from gimpcolorprofile.c:31: /usr/include/babl-0.1/babl/babl.h:111:13: note: declared here const Babl *babl_space_from_icc (const char *icc_data, ^~~~~~~~~~~~~~~~~~~
I've done a git bisect on the repository and got: /usr/local/src/git/gimp/ git bisect bad 415f869f202e76a51970b46d493ad5426f406b3a is the first bad commit commit 415f869f202e76a51970b46d493ad5426f406b3a Author: Øyvind Kolås
Date: Sat Sep 9 23:54:08 2017 +0200
app: drop workaround for bug #785521
We now hard depend on a fresher release of GEGL that already has this fix in
it.
:040000 040000 ab189c9d059e8b88cf19e56cdc6e5af83a3718e2 06e2ce3501911b986dd0de428c69ee3388988ad8 M app :040000 040000 52488dbab6b7e57b07f1e0a9006ddc6b827c90c1 ac22b839c9a9547473b65c300189e5a1b7afd007 M libgimpcolor
Regards
Jean-Luc
