GIMP development suggestion
13 of 16 messages available
GIMP development suggestion Paul Naudé 19 Aug 09:10
  CABdJpS79REZ7X729r=VKSVFXLG... 27 Aug 20:02
   CABdJpS71bJmR1oVZcGMkoRD=C0... 27 Aug 20:02
    GIMP development suggestion C R 27 Aug 20:00
     CAC=t4LasvdHGDqQOwRE=GgopqF... 28 Aug 15:44
      GIMP development suggestion C R 28 Aug 15:43
       GIMP development suggestion C R 28 Aug 16:01
        GIMP development suggestion C R 28 Aug 16:05
         GIMP development suggestion C R 28 Aug 16:09
         GIMP development suggestion Paul Naudé 28 Aug 16:14
          GIMP development suggestion C R 28 Aug 16:15
           GIMP development suggestion C R 28 Aug 16:39
  GIMP development suggestion Alexandre Prokoudine 27 Aug 19:31
   GIMP development suggestion Shlomi Fish 27 Aug 20:23
  GIMP development suggestion Ofnuts 28 Aug 20:00
   GIMP development suggestion C R 28 Aug 20:26
Paul Naudé
2017-08-19 09:10:01 UTC (over 7 years ago)
Hi
I am an everyday user of GIMP (awesome, awesome product - wish I could program to help but you guys rock) and have just one suggestion to add:
I still often need to use MS Paint, to quickly add something like a block, line or circle. Unless I am unaware of a plug in for this purpose, it would be great if GIMP could do that too (just these basic things so I can remove Paint from my taskbar altogether ;-) [image: Inlynprent 1]
My permanent taskbar shortcuts:
[image: Inlynprent 2]
Regards
Paul Naudé
2017-08-27 19:31:22 UTC (over 7 years ago)
On Sat, Aug 19, 2017 at 12:10 PM, Paul Naudé wrote:
Hi
Hi Paul,
This feature has been sitting among our low-priority goals in the roadmap for quite a few years.
Alex
C R
2017-08-27 20:00:11 UTC (over 7 years ago)
You can use the paths tool (hotkey b) to draw a shape, then do a "stroke path".
You can also make a circular or rectangular selection and drag a colour into it to fill the selection to make a solid shape.
That said, if you find you are doing this a lot, I recommend Inkscape, as it's not only easy to make shapes in the manner you are wanting, but also allows resizing and other modifications without pixelisation/blurring the results.
Until gimp fully supports vector layers, it will always be a bit of a hack to get what you want.
Hope it helps. -C
On 27 Aug 2017 19:01, "Paul Naudé" wrote:
Hi
Regards
Paul Naudé
Shlomi Fish
2017-08-27 20:23:22 UTC (over 7 years ago)
Hi
Hi Paul,
I think that lines can be drawn using the pencil tools and one can do rectangular or elliptical selections and use "stroke". If something is still missing then one can set up a bounty for implementing this feature. (I'm interested!)
Shlomi Fish       http://www.shlomifish.org/
Emma Watson Factoids - http://shlom.in/emwatson-facts
People who think they know everything greatly annoy those of us who do.
    — Source unknown, via Linux’s fortune-mod
Please reply to list if it's a mailing list post - http://shlom.in/reply .
C R
2017-08-28 15:43:44 UTC (over 7 years ago)
Hey Paul. See I'm really lazy. I hate drawing things over and over, resetting fonts, etc.
If you do this a lot, I'd set up a template (takes about 5 minutes) for it in Inkscape (this is what I do for product composition because it takes ages to move and transform things in GIMP).
Try this: 1. Open inkscape
2. Open Document properties (ctrl+shift+d), Change the units to px instead of mm.
3. Save the file as "screenshot_template_master.svg" in the same folder as your screenshots are saved. 4. Drag and drop one of your previous screenshots into the template (choose "linked" as the import type). 5. With the image still selected, hit ctrl+shift+r (this resizes the canvas to the selected object)
6. With the image still selected, right click on it and choose "image properties"
7. Under the file name get rid of all the path information and just put "1.jpg" (or 1.png if windows saves screenshots in png) 8. Lock the layer
9. make a new layer, and name it "arrows circles and junk" or whatever you like. Raise the layer to the top of the stack. 10. Off the canvas, draw a collection of circles, arrows, rectangles, etc. 11. Save the file.
With this template file you have a few options for using all your nice crisp vector bits:
A. You can simply rename the screenshot you want to "1.jpg" after windows saves it, then open your template in Inkscape. Inkscape will automatically load the new screenshot into the document for you, and you can simply move your arrows and circles around, then export.
B. If renaming files is too much work, simply drag the new screenshot into the template and choose "link".
C. If you'd rather just paste the screenshot into the document you can do that too. You don't have to turn on snapping. Just move the screenshot where you want it and use (ctrl+shift+r) to move the canvas to the new screenshot. Alternatively, turn on page corner snapping for a cleaner way to do this.
Note: If you need jpeg instead of png, install inkscape extension "export layers", and choose JPEG as the export file type.
It's a bit of setup, but the time savings is massive in redrawing/moving, rotating stuff, and you have an ever growing collection of scale-able vector elements you can use on your other projects.
Trust me, you'll be doing a file search for "master" as a regular thing after only a short time of reaping the benefits of reusable vectors.
Let me know if you have issues. :) -C
On Mon, Aug 28, 2017 at 1:02 PM, Paul Naudé wrote:
Thanks for your suggestions.
Yes I use Inkscape too, but for a quick and dirty screen shot and a "this item here" reference, MS Paint is still the quickest.
Maybe a GIMP script that links the steps you suggest could be a workaround. I will look into that.
Regards
Paul Naudé
2017-08-27 22:00 GMT+02:00 C R :
Hope it helps. -C
Hi
Regards
Paul Naudé _______________________________________________ gimp-developer-list mailing list
https://mail.gnome.org/mailman/listinfo/gimp-developer-list List archives: https://mail.gnome.org/archives/gimp-developer-list
C R
2017-08-28 16:01:42 UTC (over 7 years ago)
If you are really REALLY lazy, and don't care that much about the quality of the stroke, then do this:
In GIMP: 1. Go to Edit > Keyboard Shortcuts
2. Type "stroke" in the search bar
3. Change the shortcut for vectors-stroke-last-values from "disabled" to "Ctrl+Alt+s"
Now anytime you have a selection (circle or rectangle, or otherwise), simply hit Ctrl+Alt+s to add a stroke to it. It will be whatever colour you have currently as your foreground colour.
If the line is too thin or too thick, just hit the / key and type "stroke" into the search bar. Choose Selection to Stroke, and it will pop up the dialog for changing line width etc. The next time you use your hotkey, it will apply the same stroke you last used. this works everytime you re-open gimp too, so it's something yo probably only need to do once. :)
I don't recommend this way, but if you'd rather doe it all in GIMP, this is the easiest way.
Also note that Ctrl+, (Ctrl + comma) will fill the selection with whatever your foreground colour is. So you can get a filled and stroked shape by Ctrl+, then Ctrl+Alt+s.
Hope it helps! -C
Regards
Paul Naudé
Hope it helps. -C
Hi
Regards
C R
2017-08-28 16:05:36 UTC (over 7 years ago)
One correction: should be "select-stroke-last-values" not "vector-stroke-last-values", obviously.
-C
Hope it helps! -C
Regards
Paul Naudé
Hope it helps. -C
Hi
Regards
C R
2017-08-28 16:09:35 UTC (over 7 years ago)
This should not deter GIMP developers from adding a proper shape drawing feature. I highly recommend bribing Shlomi Fish to do it if you have the dosh. :)
-C
Hope it helps! -C
Regards
Paul Naudé
Hope it helps. -C
Hi
Regards
Paul Naudé
2017-08-28 16:14:36 UTC (over 7 years ago)
Got it, thanks! That is really helpful. Learnt quite a lot!
-C
Hope it helps! -C
etc.
11. Save the file.
"this
workaround.
Regards
Paul Naudé
"stroke
path".
colour
Inkscape, as
also
the
results.
hack
Hope it helps. -C
Hi
add:
block,
Regards
C R
2017-08-28 16:15:41 UTC (over 7 years ago)
No problem. happy GIMPing. :)
-C
-C
Hope it helps! -C
11. Save the file.
Regards
Paul Naudé
path".
results.
Hope it helps. -C
Hi
Regards
C R
2017-08-28 16:39:01 UTC (over 7 years ago)
Another note: use Shift+alt+s if you are on Ubuntu Linux - Apparently Ctrl+Alt+s is taken by the window manager to hide the window (slow disapproving head shake).
-C
-C
-C
Hope it helps! -C
11. Save the file.
Regards
Paul Naudé
path".
results.
Hope it helps. -C
Hi
Regards
2017-08-28 20:00:25 UTC (over 7 years ago)
On 08/19/17 11:10, Paul Naudé wrote:
Hi
Strangely, nobody mentioned "Filters>Render>Gfig...".
There are also several scripts available to create paths with geometric shapes.
C R
2017-08-28 20:26:23 UTC (over 7 years ago)
A nice filter, but unfortunately isn't a substitute for on-canvas editing/shape making.
Having to apply to change shape/fuzzy of brush is a bit cumbersome.
Turn this into a tool for working on canvas, with full access to the undo/redo history stack, and it would be great. :)
It still would not replace the power of vector layer support unfortunately.
Thanks for pointing it out though, Ofnuts!
Hi
