MyPaint brushes
MyPaint brushes Julien Hardelin 28 Jun 06:03
  MyPaint brushes[RESOLVED] Julien Hardelin 29 Jun 12:48
  MyPaint brushes Alexandre Prokoudine 14 Aug 15:40
Julien Hardelin
2017-06-28 06:03:24 UTC (almost 8 years ago)
MyPaint brushes
Hi all,
I can't install MyPaint brushes:
I downloaded 2 MyPaint brushes packages, unziped them and copied-pasted all files into /usr/share.gimp/2.0/brushes (or into a new MyPaint folder, or into the Legacy folder). Then I clicked on the Refresh brushes button in the Brush selection dialog.
But Mypaint brushes are not installed.
Please, can you explain me how to install these brushes.
Julien
Julien Hardelin
2017-06-29 12:48:28 UTC (almost 8 years ago)
Thank you Riota Simamoto for your help. MyPaint Brushes work ine now on my system.
Julien
2017-08-14 15:40:18 UTC (over 7 years ago)
MyPaint brushes
On Wed, Jun 28, 2017 at 9:03 AM, Julien Hardelin wrote:
Hi all,
They are in a dedicated dockable dialog.
P.S. Sorry, I've only just seen your email now.
Alex
