Dialog for scaling indeed images, (was Re: request)
Dialog for scaling indeed images, (was Re: request) Øyvind Kolås 25 Jun 17:19
  Dialog for scaling indeed images, (was Re: request) Bert de Jong 27 Jun 06:41
Øyvind Kolås
2017-06-25 17:19:39 UTC (over 7 years ago)
On Fri, Jun 23, 2017 at 2:14 PM, Bert de Jong wrote:
I think it's customary for GIMP to warn when operations initiated by the user will be performed slightly different than the user might expect.
An example is when scaling indexed images. It then says: "Indexed color layers are always scaled without interpolation. The chosen interpolation type will affect channels and layer masks only."
This warning still being present in master was a bug. Scaling; along with gaussian blur, unsharp mask, rotation, flattened down text layers and more ops, now treat indexed mode in such a way that if the palette contains relevant entries for desired in-between colors the scaling code in GEGL, and thus GIMP uses them.
The warnings is now gone in master, to get the old result - of course nearest neighbour can be chosen manually :).
With greetings Øyvind Kolås
-- http://pippin.gimp.org/
Bert de Jong
2017-06-27 06:41:48 UTC (over 7 years ago)
All right.
Regardless, some sort of warning when saving an image with transparency as JPG would be user-friendly.
Met vriendelijke groet,
Bert de Jong, Elicom B.V.
> > by
> > expect.
> > and
> > layer masks only."
> layers
> palette
