Problem with GIMP 2.9.x build dependencies
Problem with GIMP 2.9.x build dependencies | Carmelo DrRaw | 18 May 12:49 |
Problem with GIMP 2.9.x build dependencies | Carol Spears | 18 May 14:48 |
Problem with GIMP 2.9.x build dependencies | Partha Bagchi | 18 May 14:50 |
Problem with GIMP 2.9.x build dependencies | Carmelo DrRaw | 18 May 15:04 |
Problem with GIMP 2.9.x build dependencies | Partha Bagchi | 18 May 15:23 |
Problem with GIMP 2.9.x build dependencies | Carmelo DrRaw | 18 May 15:26 |
Problem with GIMP 2.9.x build dependencies | Partha Bagchi | 18 May 15:28 |
Problem with GIMP 2.9.x build dependencies | Carmelo DrRaw | 18 May 16:10 |
Problem with GIMP 2.9.x build dependencies | Partha Bagchi | 18 May 16:55 |
Problem with GIMP 2.9.x build dependencies | Kristian Rietveld | 19 May 08:09 |
Problem with GIMP 2.9.x build dependencies | Carmelo DrRaw | 21 May 18:31 |
Dear GIMP experts,
I am having troubles to compile the dependencies required to build the latest GEGL/GIMP versions from GIT.
The problem I am facing is the following:
* on one hand, GEGL requires GLIB > 2.44.0
* on the other hand, PyGTK (needed to have python support in GIMP) wants pygobject-2.0, whose latest version I could find is 2.28.6 However, this version must be compiled against a gobject-introspection version prior to this commit: https://mail.gnome.org/archives/commits-list/2011-August/msg03069.html (Deprecate ErrorDomain), otherwise one gets compilation errors due to undefined enum values. So this brings me to 1.29.16 as the latest usable gobject-introspection version (at least according to release dates, see http://ftp.gnome.org/pub/GNOME/sources/gobject-introspection/1.29/ ). However, gobject-introspection-1.29.16 cannot be compiled against glib-2.44.0 because of g_module_* functions having been moved into a sport library, which gobject-introspection-1.29.16 is not linking…
Am I doing something wrong? Is there a recommended set of library versions for compiling GIMP? Or should I patch object-introspection to add the missing glib library?
Thanks a lot in advance!
On Thu, May 18, 2017 at 8:49 AM, Carmelo DrRaw wrote:
Dear GIMP experts,
python-gtk2 contains pygobject now, for a while (if I remember correctly). I am using pygtk-2.24 and not having problems with it.
Patch for gtk3?
Dear GIMP experts,
* on the other hand, PyGTK (needed to have python support in GIMP) wants pygobject-2.0, whose latest version I could find is 2.28.6 However, this version must be compiled against a gobject-introspection version prior to this commit: https://mail.gnome.org/ archives/commits-list/2011-August/msg03069.html (Deprecate ErrorDomain), otherwise one gets compilation errors due to undefined enum values. So this brings me to 1.29.16 as the latest usable gobject-introspection version (at least according to release dates, see http://ftp.gnome.org/pub/ GNOME/sources/gobject-introspection/1.29/ ). However, gobject-introspection-1.29.16 cannot be compiled against glib-2.44.0 because of g_module_* functions having been moved into a sport library, which gobject-introspection-1.29.16 is not linking…
Use pygtk-2.24 and you should be fine.
Carol, Partha,
thanks for your help. I am already using PyGTK-2.24.0, however it searches for pygobject-2.0.pc in the PKG_CONFIG path, and that’s what forces me to use a version of pygobject not newer than 2.28.6…
Partha, could you tell me which combination of library versions are you using for your windows and OS X builds?
Thanks!
On 18 May 2017, at 16:50, Partha Bagchi wrote:
On Thu, May 18, 2017 at 8:49 AM, Carmelo DrRaw > wrote: Dear GIMP experts,
* on the other hand, PyGTK (needed to have python support in GIMP) wants pygobject-2.0, whose latest version I could find is 2.28.6 However, this version must be compiled against a gobject-introspection version prior to this commit: https://mail.gnome.org/archives/commits-list/2011-August/msg03069.html > (Deprecate ErrorDomain), otherwise one gets compilation errors due to undefined enum values. So this brings me to 1.29.16 as the latest usable gobject-introspection version (at least according to release dates, see http://ftp.gnome.org/pub/GNOME/sources/gobject-introspection/1.29/ >). However, gobject-introspection-1.29.16 cannot be compiled against glib-2.44.0 because of g_module_* functions having been moved into a sport library, which gobject-introspection-1.29.16 is not linking…
On Thu, May 18, 2017 at 11:04 AM, Carmelo DrRaw wrote:
Carol, Partha,
Thanks!
I am guessing you mean the combination of python/pygtk etc.?
I use python version 2.7.5, pycairo 1.10.0, pygobject 2.28.6, pygtk-2.24.
On 18 May 2017, at 17:23, Partha Bagchi wrote:
On Thu, May 18, 2017 at 11:04 AM, Carmelo DrRaw > wrote: Carol, Partha,
Thanks!
Could you also tell me which version of Glib you are using? That’s what is causing me troubles…
Thanks!
Carol, Partha,
Thanks!
Thanks!
Sorry. :(
My glib version is 2.53.1
Thanks!
May I also ask your gobject-introspection version?
Thanks!
Sorry. :(
On Thu, May 18, 2017 at 12:10 PM, Carmelo DrRaw wrote:
Thanks!
I don't use it.
Try to disable introspection while building pygobject-2, add the following configure option:
--enable-introspection=no
regards,
-kris.
On 18 May 2017, at 18:10, Carmelo DrRaw wrote:
Thanks!
Thanks!
Sorry. :(
Partha, Kris, Thanks!
I’ve set
for all the GTK packages and it seems it worked perfectly… no more version inconsistencies.
regards,
-kris.
Thanks!
Thanks!
Sorry. :(
