glib-networking required on Windows
| glib-networking required on Windows | programmer_ceds | 12 May 17:39 |
| glib-networking required on Windows | programmer_ceds | 13 May 10:06 |
| glib-networking required on Windows | programmer_ceds | 13 May 10:11 |
| glib-networking required on Windows | programmer_ceds | 13 May 10:14 |
| glib-networking required on Windows | programmer_ceds | 18 May 18:08 |
| glib-networking required on Windows | programmer_ceds | 18 May 18:10 |
| glib-networking required on Windows | programmer_ceds | 18 May 18:12 |
| glib-networking required on Windows | Michael Schumacher | 20 May 08:06 |
| glib-networking required on Windows | programmer_ceds | 20 May 15:15 |
| glib-networking required on Windows | Michael Schumacher | 20 May 15:28 |
| glib-networking required on Windows | programmer_ceds | 21 May 10:33 |
| glib-networking required on Windows | Jehan Pagès | 21 May 13:48 |
| glib-networking required on Windows | Carol Spears | 14 May 13:36 |
- postings
- 121
I have recently started building GIMP on Windows as per the GIMP Windows hacking page (with success until now) but have now fallen foul of the requirement for glib-networking.
I have entered the following command in MSYS2:
pacman -S mingw32/mingw-w64-i686-glib-networking
The install seemed to be successful but the GIMP autogen fails, saying that glib-networking is missing.
Can somebody tell me what else I need to do please?
- postings
- 121
By entering the following lines into mingw64 I can now get the gimp autogen to work:
Richard@HomePC MINGW64 ~ $ pacman -S base-devel \
mingw-w64-x86_64-glib-networking
Then press Enter to select all of the options.
This process automatically installs gnutls and nettle (referenced in Partha's post)
The final line of the three listed above should be added to the relevant section on the GIMP Windows hacking page.
- postings
- 121
Sorry, he above post didn't appear quite as intended. The three lines types into mingw64 should look like:
(lines typed manually now rather than cut and paste which seemed to upset the formatting)
Then press Enter to select all of the options.This process automatically installs gnutls and nettle (referenced in Partha's post)
- postings
- 121
Still wrong - try again with quotes
"Richard@HomePC MINGW64 ~"
"$ pacman -S base-devel \"
"> mingw-w64-x86_64-glib-networking"
(If that doesn't work I give up but I'm sure that the intent can be seen!)
https://mail.gnome.org/archives/gimp-developer-list/2017-May/msg00048.html
This thread in the developer list contains everything you need to know and maybe more.
- postings
- 121
I thought that I had this sorted - at least GIMP built with glib-networking the other day. Now the autogen for GIMP says that it can't find glib-networking and I can't find a .dll for it.
Trying a different tack to that noted above I have downloaded glib-networking-2.50-0 and extracted it.
I have then used the following commands which all seem to complete successfully:
./configure --without-ca-certificates --prefix=PREFIX --disable-static
make
make install
What else do I need to do to generate the required file for a Windows build of GIMP please?
- postings
- 121
./configure --without-ca-certificates --prefix=PREFIX --disable-static make
make installWhat else do I need to do to generate the required file for a Windows build of GIMP please?
(Formatting on this site caused the make to appear at the end of the configure line - but it is correct in the quoted text!)
- postings
- 121
What is it with this site? The text appeared correctly in the quoted section when I was typing the last post but when it is displayed it is wrong. What do I need to do to get the formatting that I wanted - after all it says plain text only?
You could subscribe to the original mailing list and use a proper mail client - the list is set up to allow for plain text only, to keep it usable for all clients and devices.
Regards, Michael GPG: 96A8 B38A 728A 577D 724D 60E5 F855 53EC B36D 4CDD
- postings
- 121
Having looked at the GIMP developer mailing list archives I can't say I relish having my email address exposed - I get enough spam as it is.
Perhaps I have led a sheltered existence but in over 40 years of earning a living writing and designing software I have never come across an editor (WYSIWYG or plain text) that autonomously removes line breaks.
I suppose that I will have to go back to an earlier set of sources or wait until there is a compiled version that uses glib-networking available.
For what it is worth, everything you wrote seems to show up as intended on the mailing list. This could means that the issue is display-only, or at least that the mail gimpusers.com sends to the list is left intact.
This is GIMP 2.8.22 - adding glib-networking was one of the points to make this release.
BTW, this also seems to have given us transparent proxy support - i.e. file access from locations where a proxy server is mandatory may now just work. Can anyone confirm this?
- postings
- 121
Thanks for your reply - I hadn't realised that this change had been added to V2.8 as well as 2.9.
I have found the answer to my problem. The make of glib-networking that I did had worked but I had made two mistakes. Firstly I was looking for glib-networking.dll rather than libgiognutls.dll. Secondly although I had tried putting liggiognutls.dll into my prefix lib folder it actually has to go into the prefix\lib\gio\modules folder.
At least autogen.sh now completes successfully. It might be clearer if the autogen message referred to libgiognutls (in addition to glib-networking) then at least I wouldn't have spent a while looking for the wrong file.
at least that the mail gimpusers.com sends to the list is left intact. This is GIMP 2.8.22 - adding glib-networking was one of the points to make this release.BTW, this also seems to have given us transparent proxy support - i.e. file access from locations where a proxy server is mandatory may now just work. Can anyone confirm this?
Checking out the contents of the glib-networking RPM on Fedora for instance, I see the following libs:
/usr/lib64/gio/modules/libgiognomeproxy.so /usr/lib64/gio/modules/libgiognutls.so /usr/lib64/gio/modules/libgiolibproxy.so
So there are indeed 2 additional GIO modules with the word "proxy" in it. I would assume that it explains your guess. This said, checking the prebuilt packages for Windows (both the Fedora and OpenSUSE ones), I see only one DLL:
lib/gio/modules/libgiognutls.dll
Why aren't the other proxy-related modules not built there? Are they based on technologies not available on Windows? On which platform did you notice that transparent proxy support works?
Jehan
GPG: 96A8 B38A 728A 577D 724D 60E5 F855 53EC B36D 4CDD _______________________________________________ gimp-user-list mailing list
ZeMarmot open animation film http://film.zemarmot.net Patreon: https://patreon.com/zemarmot Tipeee: https://www.tipeee.com/zemarmot
