simmetry differences
| simmetry differences | Marco Ciampa via gimp-developer-list | 10 May 11:29 |
| simmetry differences | Jehan Pagès | 11 May 00:55 |
| simmetry differences | Marco Ciampa via gimp-developer-list | 11 May 06:14 |
Hello devs!
A few little doubts in simmetry painting.
1) having both horizontal and vertical mirror simmetry painting that you can enable individually and at the same time, what is for the central simmetry for?
2) what is "disable brush transform" for?
TIA
Marco Ciampa I know a joke about UDP, but you might not get it. ------------------------ GNU/Linux User #78271 FSFE fellow #364 ------------------------
On Wed, May 10, 2017 at 1:29 PM, Marco Ciampa via gimp-developer-list wrote:
Hello devs!
Well have you tried? If you have an horizontal and a vertical symmetry, you get 3 points, very often you want a fourth one (the central symmetry). But I have not made it automatic since maybe not. Who knows? I know other software would imply the central symmetry if you do horizontal + vertical, but I don't see this as that obvious. Also you may also want only the central symmetry.
Copying an answer I made a few day ago:
When you transform the drawing, the brush itself will end up transformed as well. For instance, in a mirror transform, not only will your drawing on the right of the canvas be mirrored on the left, but the brush itself is obviously "flipped" on the left. If for some reason, you wanted the drawn lines to be mirrored (or other transformation) but not the brush outline itself, you could check this box.
For obvious reason, you won't see it with symmetrical brushes though. That's likely why you don't see the effect because many default brushes are symmetrical.
Jehan
TIA
Marco Ciampa
ZeMarmot open animation film http://film.zemarmot.net Patreon: https://patreon.com/zemarmot Tipeee: https://www.tipeee.com/zemarmot
Hello devs!
Gosh I tried but not noted the 3 points instead of four, sorry!
Well, by bad again. I tried with the "Pencil scratch" brush thinking it was asimmetrical but it clearly isn't (I do not know why, though), with "Sand Dunes (AP)" it works.
Sorry for the noise!
