RGB-clip
RGB-clip Elle Stone 29 Mar 15:24
  RGB-clip Michael Natterer 30 Mar 09:02
   RGB-clip Elle Stone 30 Mar 16:09
Elle Stone
2017-03-29 15:24:23 UTC (about 8 years ago)
RGB-clip
I'd like to (and have already started) working on writing documentation for RGB-clip.
According to Bug 778101 Missing docs: new RGB Clip filter https://bugzilla.gnome.org/show_bug.cgi?id=778101 this missing documentation bug is assigned to Róman Joost.
Would Róman Joost prefer to add the documentation for RGB clip? In which case I should stop working on this bit of documentation and find something that isn't already assigned to someone else.
I see that Joost has been assigned a lot of the documentation for GIMP color-management-related items. So I'll probably be asking this question again.
Best,
Elle
Michael Natterer
2017-03-30 09:02:39 UTC (about 8 years ago)
RGB-clip
for RGB-clip.
again.
Hi Elle,
no need to ask again, the bug assignments can be ignored, we got rid of them in the GIMP bugzilla product, because they only serve one purpose: keeping people from getting started :)
Regards, Mitch
Elle Stone
2017-03-30 16:09:23 UTC (about 8 years ago)
RGB-clip
Hi All,
Just fyi,
RGB-clip in the Colors menu requires refering to the Image/Precision menu, which isn't already in the documentation. Also "precision" needs a glossary entry.
So I'm working on all the following files at once:
Existing files:
* src/glossary.xml to change the entries that use integer values to instead use floating point values, and to add an entry for precision and other stuff as seems appropriate.
* src/menus/colors.xml to add RGB clip
* src/colors/mode.xml to move color management out of this item
* src/menus/image.xml to add/rearrange entries for precision, color management, and while I'm at it, metadata which is also missing
New files under Image menu:
* color-management.xml and sub-menus
* metadata.xml for which I might only create a stub, at least for now
* precision.xml
New file under Color menu:
* rgb-clip.xml
In case you all are getting worried, I don't anticipate having any questions :) .
Best,
L
