Shortcoming in API or behavior of gegl_node_blit and gegl_buffer_get
Øyvind Kolås
2007-09-14 12:39:36 UTC (about 18 years ago)
The main rendering functino of GEGL is gegl_node_blit, gegl_node_blit is in essence a
wrapper around gegl_buffer_get (), with a GeglNode instead of a GeglBuffer, a currently unused
rowstride of the destination_buf, and the GeglBlitFlags describing the caching behavior desired. The rowstride should probably be added to gegl_buffer_get as well, keeping the current behavior of letting 0/-1 denote a default rowstride of bytesperpixel*width.
void gegl_node_blit (GeglNode *node, GeglRectangle *roi, gdouble scale, Babl *format, gint rowstride, gpointer *destination_buf, GeglBlitFlags flags);
void gegl_buffer_get (GeglBuffer *buffer, GeglRectangle *rect, gdouble scale, Babl *format, void *dest);
If the rowstride is going to be used it should be present in gegl_buffer_get as well. The real problem is using either of these as the primitive to build a zoomable panable display. Both of them are implemented in such a manner that the GeglRectangle (x,y,width,height) specifies the integer coordinates of the upper left corner to be rendered to the linear buffer as well as the width and height of the linear buffer and the scale argument specifies the scale to be used during rendering 1.0 == 1:1, 2.0 means that each source pixel becomes a 2x2 block of pixels etc. Using this API it isn't possible to request rendering of arbitrarily positioned buffers since the upper left pixel will always be fully rendered with the upper left edge at integer coordinates.
Changing GeglRectangle to use floating point coordinates doesn't feel like a solution since almost all other places where GeglRectangles are used in GEGL it does literally mean a region of a raster in integer coordinates.
Adding horizontal and vertical offsets to the functions would clutter the API quite a bit.
What I think might be the best option will be making the scale be applied to the buffer before the rectangle is taken into account at all, and let this GeglRectangle specify integer coordinates of an already scaled buffer making the region rendered be (x/scale, y/scale, width/scale, height/scale).
Any comments?
/Øyvind K.
Øyvind Kolås
2007-09-15 21:44:31 UTC (about 18 years ago)
I'm going proceeding using this approach, the initial refactoring of the code has already landed in SVN.
/Øyvind K.
Martin Nordholts
2007-09-16 12:41:54 UTC (about 18 years ago)
Øyvind Kolås skrev:
[...] The rowstride should probably be added to gegl_buffer_get as well, keeping the current behavior of letting 0/-1 denote a default rowstride of bytesperpixel*width.
Any comments?
/Øyvind K.
Just a little comment; to increase code readability I think a symbolic constant like e.g. GEGL_DEFAULT_ROWSTRIDE should be provided by the API for passing to functions when a default rowstride is desired.
I suspect that's what you intended, just wanted to mention it.
- Martin Nordholts
Øyvind Kolås
2007-09-16 13:04:33 UTC (about 18 years ago)
On 9/16/07, Martin Nordholts wrote:
Any comments?
/Øyvind K.
Perhaps
#define GEGL_ROWSTRIDE_AUTO 0
Describes the meaning even more precisely, since it would be computing the rowstride based on the buffer width and the requested pixel format.
/Øyvind K.
