Build gegl under msys
Build gegl under msys Paul Thompson 21 Feb 17:26
  Build gegl under msys Kevin Cozens 27 Feb 15:19
Paul Thompson
2017-02-21 17:26:06 UTC (about 8 years ago)
I am attempting to build gegl and then gimp under msys. There is a good guide to this at
https://wiki.gimp.org/wiki/Hacking:Building/Windows
I followed instructions and had success until
git clone https://git.gnome.org/browse/gegl cd gegl
./autogen.sh --prefix=$PREFIX --enable-gtk-doc-html=no --disable-docs
The autogen.sh process looks for glib and cannot find it. There are no instructions for appropriate addition of this key base library to the environment. Did I incorrectly install msys or is there a way to install glib? I tried to use the git clone approach to download and build glib, but this seems wierd and too deep into the weeds.
Thanks in advance for help.
Note that Victor Oliviera had some pertinent comments.
Kevin Cozens
2017-02-27 15:19:58 UTC (about 8 years ago)
Go to gtk.org then click the Downloads link. You can download the libraries needed to build and run GIMP.
Cheers!
Kevin.
http://www.ve3syb.ca/           |"Nerds make the shiny things that distract
Owner of Elecraft K2 #2172      | the mouth-breathers, and that's why we're
                                 | powerful!"
#include  |             --Chris Hardwick
