GEGL-0.3.12 and babl-0.1.24
GEGL-0.3.12 and babl-0.1.24 Øyvind Kolås 13 Feb 20:36
Øyvind Kolås
2017-02-13 20:36:52 UTC (about 8 years ago)
GEGL provides a node/graph based API and framework for cached, interactive non-destructive image processing. GEGLs data flow image processing graphs are used by GIMP and other software like gnome-photos, imgflo and iconographer.
Highlights of changes in this release:
Core: • less locale dependent serializations/parameters • fix local raw file detection of ARW and CR2 files • gegl_memset_pattern performance improvement • clean up the way we drop references and free memory • static caching of some frequently used babl formats/types. • mipmap preview render code fixes for the following subset of operations: point
operations (filter, and composer subclasses), integer translate, crop.
Operations: • new ops: edge-neon, image-gradient, slic, wavelet-blur, waterpixels, watershed • moved from workshop to common: color-warp, component-extract • text: remove now unneeded work-around, ability to control vertical positioning, permit s hard dependencies babl and glib can be fetched from:
http://download.gimp.org/pub/babl/0.1/babl-0.1.24.tar.bz2 http://download.gimp.org/pub/gegl/0.3/gegl-0.3.12.tar.bz2
SHA256 sums of the released tarballs:
472bf1acdde5bf076e6d86f3004eea4e9b007b1377ab305ebddec99994f29d0b babl-0.1.24.tar.bz2
62eb08d7dd6ac046953a0bf606a71f9d14c9016ffef4ef7273b07b598f14bec7 gegl-0.3.12.tar.bz2
More information about GEGL can be found at the GEGL website, http://gegl.org/ or by joining #gegl and #gimp on the GIMPnet IRC network.
Have fun coding and image processing
Øyvind Kolås -– http://pippin.gimp.org/
